| » Error code F31 |
Model Number: TGF328GSF Brand: Tappan Age: 1 - 5 years
Hi my mother in law has a Tappan gas range that says F31 in the digital read out and the oven wont work now could you please help and tell me what that code means cause we cant find out anywhere.
Thanks Stephanie Ads By Google Related Models |
Stephanie,
The "F31" error code means "oven temperature probe (aka a sensor) shorted". This probe has to be checked for continuity. The normal resistance reading at the room temperature should be about 1100 Ohms. The range has to be pulled out of the wall and the rear panel has to be removed to access the plugs and wires. If the reading is wrong, replace the probe. If the reading is correct, check the wires between the probe and the control board, including all plugs. If there is nothing wrong, replace the control board (aka a clock). It is recommended by the manufacturer to replace the overlay together with clock because it is glued on. - The probe/sensor Part number: AP4433173 - The control board Part number: AP3959387 - The overlay Part number: AP2126493 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| F2 error code | Henry J | Oven Repair (including Ranges and Cooktops) | 0 | 10-30-2011 10:30 PM |
| LG error code OE - drain error | JPotter | Washer Repair | 0 | 04-01-2011 07:20 AM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
| Error code PF | fisherken1 | Oven Repair (including Ranges and Cooktops) | 0 | 12-28-2009 10:57 PM |
| Error Code F6 | MOTOJOE | Washer Repair | 3 | 08-07-2009 04:50 PM |
