When I turn my oven on, sometimes the pilot goes on and sometimes it does not but the burner does not go on. I think I might need a Thermostat for this problem but it does not turn off when I turn it off, what would I need for this problem.
I guess it's the igniters then, when I turn my oven on I get the orange glow but that's it. And sometimes when I try to shut the oven off the igniter does not go off.
Very likely the problem is a bad igniter. Also if the oven does not shut off, the control board has to be replaced too. - The oven igniter Part number: AP2020569
