| » Oven showing code F2 |
Model Number: JMW9530AAW Brand: Jenn-Air Age: 5 - 10 years
Performed an oven self clean and afterwards the fan would not shut off and the display shows a code F2. What is most likely trouble? Thanks
"F2" error code means a runaway temperature. Measure the oven sensor (#12 on the diagram) resistance which should be about 1100 Ohms at the room temperature. If there is nothing wrong then replace the relay board (#11 on the diagram).
- The part number for the oven sensor is AP4009009 - The part number for the relay board is AP4095668 Here are the breakdown diagrams and Replacement parts for JENN-AIR JMW9530AAW | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| ge washer stays in drain w/ imin showing & Code E31 & start/pause blinks sometimes | Appliabespecialists | Washer Repair | 3 | 02-08-2010 10:14 AM |
| integrated oven showing F03 fault | chrisniclia | Oven Repair (including Ranges and Cooktops) | 0 | 09-05-2009 07:44 AM |
| showing fault code please help | chrisniclia | Oven Repair (including Ranges and Cooktops) | 0 | 05-25-2009 03:08 PM |
| Oven won't bake or broil no error showing | jallen | Oven Repair (including Ranges and Cooktops) | 3 | 02-03-2009 12:22 PM |
| Oven is making beep music and showing error codes F1 and F0 | sandmn3 | Oven Repair (including Ranges and Cooktops) | 7 | 12-26-2008 07:09 PM |
