Discuss
kitchen aid oven stopped running
 in
My oven stopped a little while ago, and while looking for the problem, I came across what looks like a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » kitchen aid oven stopped running
  #1 (permalink)
Old 05-19-2009, 03:09 PM
Junior Member
TomW is on a distinguished road
Default kitchen aid oven stopped running
Model Number: kebs277dwh1   Brand: Kitchen Aid   Age: More than 10 years
My oven stopped a little while ago, and while looking for the problem, I came across what looks like a cartridge fuse on the back of the control panel.With power on, there is a 115v drop across the fuse, and with power off, it shows an open circuit. the problem is, it does not look like it is intended to be replaced - both ends are in closed pockets, which are then wired into the circuit board.
This looks like the problem to me, but I am unsure if I can replace it, or what size fuse it is. any suggestions?
It is located in approximately the middle of the top of the back of the panel circuit board
Ads By Google
Related Models
Whirlpool KEBS277DWH1
Whirlpool KEBS277DWH10
Whirlpool KEBS277DWH11
Whirlpool KEBS277DWH12
Whirlpool KEBS277DWH2
Whirlpool KEBS277DWH4
Whirlpool KEBS277DWH6
Whirlpool KEBS277DWH7
Whirlpool KEBS277DWH8
Whirlpool KEBS277DWH9
Whirlpool KEBS277SBL0
Whirlpool KEBS277SBL00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS277SBL1
Whirlpool KEBS277SBL2
Whirlpool KEBS277SSS00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS277SWH0
Whirlpool KEBS277SWH00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS277SWH1
Whirlpool KEBS277SWH2
Whirlpool KEBS277WAL0
Whirlpool KEBS277WAL1
Whirlpool KEBS277WAL2
Whirlpool KEBS277WAL3
Whirlpool KEBS277WBL0
Whirlpool KEBS277WBL1
Whirlpool KEBS277WBL2
Whirlpool KEBS277WBL3
Whirlpool KEBS277WWH0
Whirlpool KEBS277WWH1
Whirlpool KEBS277WWH2
Whirlpool KEBS277WWH3
Whirlpool KEBS277XAL0
Whirlpool KEBS277XAL3
Whirlpool KEBS277XBL0
Whirlpool KEBS277XBL2
Whirlpool KEBS277XBL3
Whirlpool KEBS277XWH0
Whirlpool KEBS277XWH2
Whirlpool KEBS277XWH3
Whirlpool KEBS277YAL0
Whirlpool KEBS277YAL1
Whirlpool KEBS277YAL2
Whirlpool KEBS277YAL3
Whirlpool KEBS277YAL4
Whirlpool KEBS277YBL0
Whirlpool KEBS277YBL1
Whirlpool KEBS277YBL2
Whirlpool KEBS277YBL3
Whirlpool KEBS277YBL4
Whirlpool KEBS277YWH0
Whirlpool KEBS277YWH1
Whirlpool KEBS277YWH2
Whirlpool KEBS277YWH3
Whirlpool KEBS277YWH4
Whirlpool KEBS278AAL0
Whirlpool KEBS278AAL1
Whirlpool KEBS278ABL0
Whirlpool KEBS278ABL1
Whirlpool KEBS278AWH0
Whirlpool KEBS278AWH1
Whirlpool KEBS278BAL0
Whirlpool KEBS278BAL1
Whirlpool KEBS278BAL2
Whirlpool KEBS278BAL3
Whirlpool KEBS278BBL0
Whirlpool KEBS278BBL1
Whirlpool KEBS278BBL2
Whirlpool KEBS278BBL3
Whirlpool KEBS278BWH0
Whirlpool KEBS278BWH1
Whirlpool KEBS278BWH2
Whirlpool KEBS278BWH3
Whirlpool KEBS278DBL1
Whirlpool KEBS278DBL10
Whirlpool KEBS278DBL11
Whirlpool KEBS278DBL2
Whirlpool KEBS278DBL4
Whirlpool KEBS278DBL6
Whirlpool KEBS278DBL7
Whirlpool KEBS278DBL8
Whirlpool KEBS278DBL9
Whirlpool KEBS278DBS10
Whirlpool KEBS278DBS11
Whirlpool KEBS278DBS6
Whirlpool KEBS278DBS7
Whirlpool KEBS278DBS8
Whirlpool KEBS278DBS9
Whirlpool KEBS278DSS10
Whirlpool KEBS278DSS11
Whirlpool KEBS278DSS6
Whirlpool KEBS278DSS7
Whirlpool KEBS278DSS8
Whirlpool KEBS278DSS9
Whirlpool KEBS278DWH1
Whirlpool KEBS278DWH10
Whirlpool KEBS278DWH11
Whirlpool KEBS278DWH2
Whirlpool KEBS278DWH4
Whirlpool KEBS278DWH6
Whirlpool KEBS278DWH7
Whirlpool KEBS278DWH8
Whirlpool KEBS278DWH9
Whirlpool KEBS278SBL00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS278SSS00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS278SWH00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBU107SSS00 30" Built - in Electric Single Oven
Whirlpool KEBU208SSS00 30" Built - in Electric Double Oven
Whirlpool KEBV107PMT00 30" Built - in Electric Oven Thermal Convection
Whirlpool KEBV107PMT01 30" Built - in Electric Oven Thermal Convection
Whirlpool KEBV107PSS00 30" Built - in Electric Oven Thermal Convection
Whirlpool KEBV107PSS01 30" Built - in Electric Oven Thermal Convection
Whirlpool KEBV208MMT00 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBV208MMT02 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBV208MMT03 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBV208MSS00 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBV208MSS02 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBV208MSS03 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Frigidaire KEC3M6NSAA Gib(v1) / Electric Range
Frigidaire KEC457NSAA Gib(v1) / Electric Range
Whirlpool KECC027YAL0
  #2 (permalink)
Old 05-19-2009, 07:13 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL KEBS277DWH1 | AppliancePartsPros.com
Here is a tech sheet.
https://www.servicematters.com/docs/...%204450937.pdf
There is a thermal fuse, it is Item 19 in the "Top venting" section. It does not look like it is on the control board.
It will kill power to the control board.
Cannot see anything like a fuse on the back of the board, using the parts list photos.
If the device you are referring to has colored bands on it then it is probably a resistor. The bands tell you what resistance it should be. It may read as an open depending on what scale you have your meter set at.
__________________
  #3 (permalink)
Old 05-20-2009, 05:41 AM
Junior Member
Default
Denman
Thanks for the response.
This is not a standard resistor, it is a glass tube with metal ends, and a strip of metal running down the center, pretty much like any cartridge fuse, I would normally expect the glass to be smoked by the fuse burning out, but it is not, so I am still unsure about it.
The strange thing about it is that it is not in a mount allowing easy replacement. The ends are set into round caps, which are soldered into the c/b. Looking at it, it is right between five black cubical components, and the connector for the ribbon cable to the display.
TomW
  #4 (permalink)
Old 05-20-2009, 05:46 AM
Junior Member
Default
Denman
In your #2 photo it is at the top center of the board just above the "a" in Parts of Appliancepartspros.com
  #5 (permalink)
Old 05-20-2009, 06:14 AM
Senior Expert
APP Volunteer
Default
On the picture it looks like they have a jumper here
Could be yours has an update or is an earlier revision of the board.
It is not that uncommon for manufactures to hard wire fuses onto a board.
Saves them a penny on the board.
Definitely does sound like a fuse
Since it measures open I would replace it.
Once you unsolder one of the caps and remove the fuse, odds are high that the rating will be stamped on the fuse.
If not a 1 or 2 amp fuse should do, after all you have nothing to loose.
Have to run, am off to the lake for a couple days.
Good luck.
__________________
  #6 (permalink)
Old 05-20-2009, 06:18 AM
Junior Member
Default
Denman
I will try that
Thanks for the help, and enjoy the lake
TomW
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kitchen aid KUDK03ITWH2 stopped no lights nolman23 Dishwasher Repair 1 10-12-2009 06:54 PM
Kitchen Aid Ice Maker stopped working wocao Refrigerator & Freezer Repair 1 10-06-2009 05:33 AM
Dryer stopped running Robin Edgar Dryer Repair 11 08-14-2009 10:55 AM
Kitchen Aid Ice Maker stopped working E Jim K Refrigerator & Freezer Repair 3 07-04-2009 03:20 AM
just stopped running johnthehandyman Dryer Repair 3 09-16-2008 05:26 PM
