Discuss
Oven doesn't work.
 in
Dear Technical help, I have the above gas cooker. The Model number above is inside the door. There are also
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven doesn't work.
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-13-2007, 09:54 AM
Laurence Reeve Laurence Reeve is offline
Junior Member
Laurence Reeve is on a distinguished road
Default Oven doesn't work.
Model Number: 8114P471-60   Brand: Magic Chef   Age: 5 - 10 years
The Model number above is inside the door. There are also these numbers or codes on the manual covers: 8113P166-60 (06-97-00); 8110P226-60 (08-97-00).
The cooker has 'super capacity' and 'magic chef' written on it too.
A fault code appears 'F1' and then there is a beep when I try to operate the oven. It won't allow me to set the time either as the fault code interferes: 'F1'.
The four burners work fine.
I have only recently obtained the cooker and have never had the oven working before.
My manual only says to contact a technician if a fault code appears. Nobody in Ireland has a clue as it is an import from the USA.
Do you have any advice please?
Thank you,
Laurence Reeve
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven won't work markf Oven Repair (including Ranges and Cooktops) 0 11-06-2007 10:17 AM
GE Oven - Broiler does not work martincregg Oven Repair (including Ranges and Cooktops) 1 09-01-2007 10:46 AM
Oven Does Not Work JEANNIE Oven Repair (including Ranges and Cooktops) 6 08-29-2007 02:07 PM
Oven does not work... Ruben Oven Repair (including Ranges and Cooktops) 1 08-17-2007 08:02 AM
oven won't work cherylknudsen Oven Repair (including Ranges and Cooktops) 1 08-11-2007 04:43 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
