I ordered a part from Appliance Parts Pros, # 9782419CB. Its a control panel for my kitchenaid superba. It's the same part as seen on the website, but there's a problem. There's no way to connect the wire ribbon to the control board. It appears the part was shipped without the B3 and A7 amp connectors on the end of the ribbon wire, just like it appears on the website.
I either need to return the part or find a way to attach the ribbon wire to the control board, since the replacement part is currently not compatible.
any ideas?
