Discuss
Dead Whirlpool Range
 in
Our range has been acting up more and more. The power would frequently flash off and the display would reset
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Dead Whirlpool Range
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-12-2007, 07:03 PM
jaybosserman jaybosserman is offline
Junior Member
jaybosserman is on a distinguished road
Cool Dead Whirlpool Range
Model Number: SF387LEKT   Brand: Whirlpool   Age: 5 - 10 years
Our range has been acting up more and more. The power would frequently flash off and the display would reset itself. Sometimes it completely blanked and would not power up without pressing the buttons. Sometimes it would take multiple attempts to get it running but eventually it would fail again. The display is now blank but the buttons beep, the oven lights, and the stove lights. I am getting +5VDC to the main board and -30VDC on the -20V line. The AC line gives me 2.4VAC.
It looks like the control panel is dead but is my power supply also shot? Replacing both takes me about half way to the cost of a new oven. Are supply outputs in line? Need some help, thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-12-2007, 07:41 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is how good is the ground to the range.
Per your description most likely the problem is a bad control board, but because I do not have the low voltage chart I can not tell you if the power supply board is bad too.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help! Dead Whirlpool Duet GHW9200LW Richduet Washer Repair 6 01-17-2008 05:47 AM
Whirlpool Range PF code Gallo Oven Repair (including Ranges and Cooktops) 0 10-31-2007 05:54 PM
whirlpool seneon dryer dead tnash542 Dryer Repair 0 10-15-2007 04:38 AM
F3 Error code on whirlpool Range Larry56 Oven Repair (including Ranges and Cooktops) 1 09-10-2007 06:06 PM
GE Range Display Dead markham Oven Repair (including Ranges and Cooktops) 0 07-25-2007 08:59 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
