Discuss
piolet not lighting
 in
No ignition when stove burners or oven turned on. No clicking sound burner is turned on.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » piolet not lighting
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-12-2007, 05:02 PM
kim1234 kim1234 is offline
Junior Member
kim1234 is on a distinguished road
Default piolet not lighting
Model Number: 31HN2KXON   Brand: Magic Chef   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-12-2007, 06:51 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the power to the range. Check the power outlet for 120V.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-13-2007, 08:34 AM
doug1 doug1 is offline
Junior Member
doug1 is on a distinguished road
Default
The clock is working on the stove so that could not be it. Any other ideas?
  #4 (permalink)
Old 12-13-2007, 06:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the oven igniters not working as well as the top ignition - most likely the problem is related to the power source.
Check the power cord connection to the range and the terminal block inside the range.
Check all incoming wires.
It very unusual if the spark module and the oven igniter broke at the same time.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
thermador range extra low burner not lighting BILL20850 Oven Repair (including Ranges and Cooktops) 0 10-08-2007 02:44 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
