piolet not lighting
No ignition when stove burners or oven turned on. No clicking sound burner is turned on.
The first thing I would check is the power to the range. Check the power outlet for 120V.
Gene. |
The clock is working on the stove so that could not be it. Any other ideas?
If the oven igniters not working as well as the top ignition - most likely the problem is related to the power source.
Check the power cord connection to the range and the terminal block inside the range. Check all incoming wires. It very unusual if the spark module and the oven igniter broke at the same time. Gene. |
| All times are GMT -7. The time now is 05:38 PM. |
