Discuss
Oven door glass repair
 in
I need to know how to replace the inside oven door glass on my Dacor oven. I've got the part
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven door glass repair
  #1 (permalink)
Old 12-12-2007, 04:51 PM
Junior Member
Barry White is on a distinguished road
Question Oven door glass repair
Model Number: CPS130   Brand: Dacor   Age: More than 10 years
I need to know how to replace the inside oven door glass on my Dacor oven. I've got the part but am not sure how to remove the old glass and replace it. Any suggestions ? Thanks in advance for any info you give.
Ads By Google
Related Models
Whirlpool CPT08D1A1
Whirlpool CPT08DA1A
Whirlpool CPT18C2A1
Crosley CR1100K Mwave - Cntrtp / Stand Alone
Crosley CR1100KG Mwave - Cntrtp / Stand Alone
Crosley CR1100KW Mwave - Cntrtp / Stand Alone
Amana CR14 Misc / Accessory
Amana CR14L Misc / Accessory
Crosley CR151K Mwave - Cntrtp / Stand Alone
Crosley CR151KWH Mwave - Cntrtp / Stand Alone
Crosley CR151WH Mwave - Cntrtp / Stand Alone
Crosley CR153K Mwave - Cntrtp / Stand Alone
Crosley CR154K Mwave - Cntrtp / Stand Alone
Crosley CR154KWH Mwave - Cntrtp / Stand Alone
Whirlpool CR18PKXRS00 Refrigerator
Whirlpool CR18PKXRS01 Refrigerator
Jenn-Air CR220B Surf Cont Panel Unit - Ddft Ele
Jenn-Air CR220B-C Surf Cont Panel Unit - Ddft Ele
Jenn-Air CR220W Surf Cont Panel Unit - Ddft Ele
Jenn-Air CR220W-C Surf Cont Panel Unit - Ddft Ele
Thermador CR30
Frigidaire CR302VP2D03 Frg(v1) / Gas Range
Frigidaire CR302VP2W03 Frg(v2) / Gas Range
Thermador CR30W
Thermador CR36
Thermador CR36W
Crosley CR4100 Mwave - Cntrtp / Stand Alone
Crosley CR4200 Mwave - Cntrtp / Stand Alone
Crosley CR4614K Mwave - Cntrtp / Stand Alone
Crosley CR4614KWH Mwave - Cntrtp / Stand Alone
Crosley CR464B Mwave - Cntrtp / Stand Alone
Magic Chef CRB21EA-3A Ref - Top Mount
Magic Chef CRB21EN-3A Ref - Top Mount
Magic Chef CRB21EY-3A Ref - Top Mount
Magic Chef CRB22EA-3AI Ref - Top Mount/ I&W
Magic Chef CRB22EN-3AI Ref - Top Mount/ I&W
Magic Chef CRB22EY-3AI Ref - Top Mount/ I&W
Amana CRC10T Commercial Microwaves
Amana CRC10T2 Commercial Microwaves
Amana CRC12T Commercial Microwaves
Amana CRC12T2 Commercial Microwaves
Amana CRC18T2 Commercial Microwaves
Amana CRC18T2OG Commercial Microwaves
Amana CRC18T2OG2  Commercial Microwaves
Amana CRC18T2SD Commercial Microwaves
Amana CRC21T2 Commercial Microwaves
Amana CRC21T2RL Commercial Microwaves
Amana CRC21T2RL2  Commercial Microwaves
Magic Chef CRC22EA-3AW Ref - SXS/I&W
Magic Chef CRC22EN-3AW Ref - SXS/I&W
Magic Chef CRC22EY-3AW Ref - SXS/I&W
Magic Chef CRC24EA-3AI Ref - SXS/I&W
Magic Chef CRC24EN-3AI Ref - SXS/I&W
Magic Chef CRC24EY-3AI Ref - SXS/I&W
Amana CRC510T2 Commercial Microwaves
Amana CRC514D Commercial Microwaves
Amana CRC514T2 Commercial Microwaves
Amana CRC518D Commercial Microwaves
Amana CRC518T2 Commercial Microwaves
Amana CRC8 Commercial Microwaves
Amana CRCR-7 Mwave - Mounted Over Range/wo
Amana CRCR8 Walloven - Std Mwave Ele
Magic Chef CRD22AY-3A Ref - Sxs
Magic Chef CRD22EA-3A Ref - Sxs
Magic Chef CRD22EN-3A Ref - Sxs
Magic Chef CRD22EY-3A Ref - Sxs
Maytag CRE0305ACW Range - F/s Std Ele
Maytag CRE0655ACW Range - S/c F/s Ele
Maytag CRE0775ACW Range - S/c F/s Ele
Amana CRE14 Misc / Accessory
Maytag CRE200 Range - F/s Std Ele
Maytag CRE200B Range - F/s Std Ele
Maytag CRE300 Range - F/s Std Ele
Maytag CRE300B Range - F/s Std Ele
Maytag CRE305 Range - F/s Std Ele
Maytag CRE350 Range - F/s Std Ele
Maytag CRE350B Range - F/s Std Ele
Maytag CRE355 Range - F/s Std Ele
Maytag CRE383 Range - F/s Std Ele
Maytag CRE400 Range - F/s Std Ele
Maytag CRE400B Range - F/s Std Ele
Maytag CRE500 Range - F/s Std Ele
Maytag CRE500B Range - F/s Std Ele
Maytag CRE600 Range - F/s Std Ele
Maytag CRE600B Range - F/s Std Ele
Maytag CRE650 Range - F/s Std Ele
Maytag CRE655 Range - S/c F/s Ele
Maytag CRE682 Range - S/c F/s Ele
Maytag CRE682B Range - S/c F/s Ele
Maytag CRE683 Range - S/c F/s Ele
Maytag CRE700 Range - S/c F/s Ele
Maytag CRE750 Range - S/c F/s Ele
Maytag CRE7500ACL Range - F/s Std Ele
  #2 (permalink)
Old 12-12-2007, 06:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Attached you find the Oven door break down diagram.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-16-2007, 11:07 PM
Junior Member
Default
Gene - thanx for the oven door diagram. I'll give it a go.
  #4 (permalink)
Old 12-16-2007, 11:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
  #5 (permalink)
Old 12-29-2007, 06:28 PM
Junior Member
Thumbs up Dacor oven door glass replacement
Gene,
Thanx again for the detailed expanded diagram. It sure helped. I got the old part out ok and went to install the new glass unit only to find it defective. One of the mounting tabs on the frame of it was missing. I just removed the frame of the old one and used it. Took a bit more time but it all worked out in the end. Oven now works great.
Barry
  #6 (permalink)
Old 12-29-2007, 06:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
Happy New year!
__________________
  #7 (permalink)
Old 12-31-2007, 06:59 PM
Junior Member
Default Dacor oven door glass repair
Thanks again for your help. Happy New Year to you and yours as well!!
  #8 (permalink)
Old 12-19-2008, 10:58 AM
wkh wkh is offline
Junior Member
wkh is on a distinguished road
Default inside glass
it seems I want the glass assembly
do i need to take off the door from the oven to gain access to the screws to dissassemble? should i replace the outside metal gasket at the same time or can i put it back?
thanks
  #9 (permalink)
Old 12-19-2008, 12:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
wkh,
What is the complete model number of the oven? The oven door always has to be removed for any repair.
__________________
  #10 (permalink)
Old 11-23-2009, 10:29 AM
Junior Member
awhittak is on a distinguished road
Default
How do you remove the oven door on the CPS130
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven glass repair renew hart Oven Repair (including Ranges and Cooktops) 1 01-05-2010 03:06 PM
Wall oven, outer glass door repair Kirk_at_the_beach Oven Repair (including Ranges and Cooktops) 0 10-13-2009 04:03 PM
outer glass door repair marion rodgers Oven Repair (including Ranges and Cooktops) 0 08-10-2009 09:10 AM
Oven Glass Door Repair olgallegos Oven Repair (including Ranges and Cooktops) 0 01-29-2009 01:29 PM
inner oven glass door lady1167 Oven Repair (including Ranges and Cooktops) 0 03-06-2008 04:51 PM
