Bake element heats but broiler will not heat. Have checked line voltage, 240v; element impedance, 17-20 ohms; voltage at element, 120v. What other possibilities can be checked? The rest of the range is operating. How do I confirm that the expensive electronic control board is at fault? Please help!:eek:
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Thank you for responding! I have checked what I believe is the thermal fuse; a brown plastic/ceramic rectangle about 1" long onthe back of the oven. The wiring colors are correct on the schematic you included; this fuse has good continuity. Thank you for including the wiring diagram! Is it possible to be the rtd?:rolleyes:
Should not be the RTD as the bake element would also not work.
Sounds like the control board is toast. |
Originally Posted by: denman Should not be the RTD as the bake element would also not work.
Sounds like the control board is toast. That was my first thought, keep hoping to find a cheaper fix. :confused: Thank you for your help!:D
Any prcautions or tricks to install the new control board? :confused:
It should be fairly straight forward.
If you have a problem with static electricity in your house ground your self before starting. If you have copper plumbing then just grab a copper pipe under the sink for a couple seconds and that should get your body to Neutral. |
