I Bought It Over A Year Ago In Clearence And Has Not Been Used Until Now. I Turned It On On It Worked For 2 Minutes, There Was A Funny Smell And That Was It. The Oven Doent Work Either. The Light Are On And So Is The Clock And My Husband Already Check The Power. I Need Help!!! It's Out Of Warranty
If you had it stored where rodents could possibly get in it, I would check the wiring. They like to gnaw things like that. Make sure the power you're getting is 240VAC; with 120VAC coming from each hot leg in the receptacle to the ground.
We can't diagnose a "funny smell" very well, unless you can accurately describe it; but with your patience (and your meter), we can help walk you through the troubleshooting. What you DON'T want to do is panic, and start indiscriminately throwing parts at the repair. We can help you narrow it down.
