Discuss
Jenn-Air range turns itself off for no reason, beeps continually
 in
Normally, one hits 'Bake' button, dials temp, and waits until oven heats up. About 6 months ago, the range began
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air range turns itself off for no reason, beeps continually
  #1 (permalink)
Old 11-02-2011, 06:19 PM
Junior Member
ljc2 is on a distinguished road
Default Jenn-Air range turns itself off for no reason, beeps continually
Model Number: S176B   Brand: Jenn-Air   Age: More than 10 years
Normally, one hits 'Bake' button, dials temp, and waits until oven heats up. About 6 months ago, the range began to turn off after a minute of so in pre heat. This could be overcome by hitting and holding the 'Bake' button a second time while oven was heating up; actually, holding the 'Bake' button until you heard a clicking sound. Recently, this workaround stopped working. Oven shuts off and you get persistent beeping, which is only stopped by cutting power to range.
Also recently, a F0 code was displayed once or twice. Evidently, F0 code indicates, "Function key stuck." Solution is "Replace touch pad or, if touch pad is part of the clock, replace the clock. My understanding is that, for the S176, the keypad is separate. Furthermore, the keypad is unavailable.
Suggestions? Would I be right in that it's time to replace the range?
Ads By Google
Related Models
Jenn-Air S176B Range - S/c S/i Ddraft Ele
Jenn-Air S176W Range - S/c S/i Ddraft Ele
Amana S19E Ref - SXS/I&W
Frigidaire S2-06B1E Kel(v0) / Room Air Conditioner
Amana S20 Freezer - Vertical
General Electric S2000D0WW Washer
General Electric S2000D2WW Washer
General Electric S2000D5WW Washer
Hoover S2001---
Hoover S2003--- Stick - Handy,broom,light Wt,compact
Hoover S2005--- Stick - Handy,broom,light Wt,compact
Hoover S2007--- Stick - Handy,broom,light Wt,compact
Hoover S2009--- Stick - Handy,broom,light Wt,compact
Hoover S2011--- Stick - Handy,broom,light Wt,compact
Hoover S2013--- Stick - Handy,broom,light Wt,compact
Hoover S2015--- Stick - Handy,broom,light Wt,compact
Hoover S2029--- Stick - Handy,broom,light Wt,compact
Hoover S2031--- Stick - Handy,broom,light Wt,compact
Hoover S2033--- Stick - Handy,broom,light Wt,compact
Hoover S2037--- Stick - Handy,broom,light Wt,compact
Hoover S2039--- Stick - Handy,broom,light Wt,compact
Hoover S2041--- Stick - Handy,broom,light Wt,compact
Hoover S2043--- Stick - Handy,broom,light Wt,compact
Hoover S2047--- Stick - Handy,broom,light Wt,compact
Frigidaire S204F1SA Kel(v1) / Room Air Conditioner
Hoover S2053--- Stick - Handy,broom,light Wt,compact
Hoover S2053032 Stick - Handy,broom,light Wt,compact
Hoover S2053042 Stick - Handy,broom,light Wt,compact
Hoover S2053942 Stick - Handy,broom,light Wt,compact
Hoover S2055--- Stick - Handy,broom,light Wt,compact
Hoover S2057--- Stick - Handy,broom,light Wt,compact
Frigidaire S205A1QA Kel(v0) / Room Air Conditioner
Hoover S2085--- Stick - Handy,broom,light Wt,compact
Hoover S2087--- Stick - Handy,broom,light Wt,compact
Hoover S2087900 Stick - Handy,broom,light Wt,compact
Frigidaire S208C1E Kel(v1) / Room Air Conditioner
Frigidaire S208C1E2 Kel(v1) / Room Air Conditioner
Frigidaire S208C1QA Kel(v0) / Room Air Conditioner
Frigidaire S208D1QA Kel(v1) / Air Conditioner
Hoover S2095--- Stick - Handy,broom,light Wt,compact
Hoover S2097--- Stick - Handy,broom,light Wt,compact
Hoover S2099--- Stick - Handy,broom,light Wt,compact
Amana S20A Freezer - Vertical
General Electric S2100E1WW Washer
General Electric S2100E4WW Washer
General Electric S2100E6WW Washer
General Electric S2100E7WW Washer
General Electric S2100G0WW Washer
General Electric S2100G2WW Washer
Hoover S2103--- Stick - Handy,broom,light Wt,compact
Hoover S2105--- Stick - Handy,broom,light Wt,compact
Hoover S2105050 Stick - Handy,broom,light Wt,compact
Hoover S2105180
Hoover S2131--- Stick - Handy,broom,light Wt,compact
Hoover S2135--- Stick - Handy,broom,light Wt,compact
Hoover S2139080 Stick - Handy,broom,light Wt,compact
Hoover S2141--- Stick - Handy,broom,light Wt,compact
Hoover S2147--- Stick - Handy,broom,light Wt,compact
Hoover S2149--- Stick - Handy,broom,light Wt,compact
Hoover S2155--- Stick - Handy,broom,light Wt,compact
Hoover S2200--- Stick - Handy,broom,light Wt,compact
Hoover S2200001 Stick - Handy,broom,light Wt,compact
General Electric S2200Y0WW Washer
General Electric S2200Y1WW Washer
General Electric S2200Y3WW Washer
Hoover S2201--- Stick - Handy,broom,light Wt,compact
Hoover S2203--- Stick - Handy,broom,light Wt,compact
Hoover S2211--- Stick - Handy,broom,light Wt,compact
Hoover S2211100 Stick - Handy,broom,light Wt,compact
Hoover S2220--- Stick - Handy,broom,light Wt,compact
Magic Chef S22FA-2KLX Range - Cont Clean Dbl Oven Gas
Magic Chef S22FK-2KLX Range - Cont Clean Dbl Oven Gas
Magic Chef S22FN-2KLX Range - Cont Clean Dbl Oven Gas
Magic Chef S22FY-2KLX Range - Cont Clean Dbl Oven Gas
Amana S23 Freezer - Vertical
Amana S23A Freezer - Vertical
Amana S23B Freezer - Vertical
Amana S25 Freezer - Vertical
Hoover S2505--- Stick - Handy,broom,light Wt,compact
Hoover S2509--- Stick - Handy,broom,light Wt,compact
Hoover S2515
Hoover S2531--- Stick - Handy,broom,light Wt,compact
Hoover S2535--- Stick - Handy,broom,light Wt,compact
Hoover S2541--- Stick - Handy,broom,light Wt,compact
Hoover S2541040 Stick - Handy,broom,light Wt,compact
Hoover S2543--- Stick - Handy,broom,light Wt,compact
Hoover S2545--- Stick - Handy,broom,light Wt,compact
Hoover S2551--- Stick - Handy,broom,light Wt,compact
Hoover S2551050 Stick - Handy,broom,light Wt,compact
Hoover S2561--- Stick - Handy,broom,light Wt,compact
Hoover S2561050 Stick - Handy,broom,light Wt,compact
Hoover S2569--- Stick - Handy,broom,light Wt,compact
Hoover S2571--- Stick - Handy,broom,light Wt,compact
Amana S25A Freezer - Vertical
Hoover S2610--- Stick - Handy,broom,light Wt,compact
Thermador S272T
Magic Chef S28FA-7CXWV8 Range - S/c Mwave Ele
Magic Chef S28FK-7CXWV8 Range - S/c Mwave Ele
Magic Chef S28FN-7CXWV8 Range - S/c Mwave Ele
Magic Chef S28FS-7CXWV8 Range - S/c Mwave Ele
Magic Chef S28FY-7CXWV8 Range - S/c Mwave Ele
Hoover S3001--- Cstr - Spherical,saucer,lc,elec,tp Swivel
Hoover S3001001
Hoover S3001011 Cstr - Spherical,saucer,lc,elec,tp Swivel
Hoover S3003--- Cstr - Spherical,saucer,lc,elec,tp Swivel
Hoover S3003001
Hoover S3003030 Cstr - Spherical,saucer,lc,elec,tp Swivel
Hoover S3005--- Cstr - Spherical,saucer,lc,elec,tp Swivel
Hoover S3005001
Hoover S3005020
Hoover S3005030 Cstr - Spherical,saucer,lc,elec,tp Swivel
Hoover S3007
Hoover S3009
Hoover S3009051
Hoover S3011
Hoover S3011001
Hoover S3013--- Port - Slim Style,suitcase,power,compact
Hoover S3013001
Hoover S3013035 Port - Slim Style,suitcase,power,compact
Hoover S3015--- Port - Slim Style,suitcase,power,compact
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Oasis Turns on by itself/beeps/arbitrarily changes settings kingirp Washer Repair 1 02-16-2011 06:53 AM
Jenn-Air Wall Oven - Beeps with Code 'FC' Janmon Oven Repair (including Ranges and Cooktops) 1 10-29-2010 03:14 PM
Kenmore washer-Beeps continually HawkFan64 Washer Repair 4 02-20-2010 02:43 PM
Whirlpool Double Builtin Oven LED OUT, TURNS ON FOR ABOUT 10 SECONDS THEN BEEPS bearingrnwd Oven Repair (including Ranges and Cooktops) 0 12-20-2009 07:17 PM
F4/F3 Error Sensor; Turns on automatically and beeps jnchay Microwave Repair 0 05-03-2009 09:31 AM
