| » need help woth removing Venturi tube on top near burner |
What is the complete model number of the stove?
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
If a 20mm socket did not work, try a 25/32" socket. Do not use too much force because it is very easy to break a gas tubes under the top panel. If a nut does not come off, you have to cut it off.
Here are the breakdown diagrams and Burner box replacement parts for THERMADOR PRSE484GGS ELECTRIC/GAS RANGE | AppliancePartsPros.com Gene.
__________________
[quote=Gene;575613]If a 20mm socket did not work, try a 25/32" socket. Do not use too much force because it is very easy to break a gas tubes under the top panel. If a nut does not come off, you have to cut it off.
ok great i will try a 25/32 socket first,im trying to replace the two pans that are connected to the 4 burners,so i need to take off the 4 tubes and there are all really tight,i tryed 3 in one lubricate and its still tight,thanks |
[quote=hawaiisurf777;575622]
Quote:
There are no venturi tubes used in this stove. Instead there are jet holders (under the top panel) and nuts on of it.
__________________
[quote=Gene;575629]There are no venturi tubes used in this stove. Instead there are jet holders (under the top panel) and nuts on of it.
|||| this is what im trying to get off from the top,,,Venturi tube - Size: 10.5 mm. D burner Part Number: AP2825260 made by BOSCH |
| Display Modes | |
| Burner Tube 189321 | ATerryS | Oven Repair (including Ranges and Cooktops) | 1 | 02-16-2011 06:21 AM |
| Removing Thermador burner venturi | kwiq | Oven Repair (including Ranges and Cooktops) | 1 | 08-10-2010 09:32 PM |
| Ge Stove burner tube | MATT BROOKER | Oven Repair (including Ranges and Cooktops) | 0 | 07-22-2009 08:55 AM |
| need burner tube and exhaust temps | 3rdskunks | Dryer Repair | 0 | 05-07-2009 02:36 PM |
| aluminum tube burner connections | dankreuz | Oven Repair (including Ranges and Cooktops) | 3 | 03-13-2009 10:04 AM |
