| » Oven slow to heat up |
Model Number: 30-3982-00/01 Brand: Tappan Age: More than 10 years
The last 2 times I used the oven, I turned the oven to bake on 350 degrees and the oven took about 5 minutes for the burner to go on. Both times there was a slight but definite smell of gas. After the burner went on, the oven worked fine and the gas odor disappeared. I am prepared to call a stove repairman, but am wondering if I can do anything to fix it.
Most likely the problem with your oven is a bad bake igniter (#18 on the gas control break down diagram).
Replacing the igniter should solve the problem. If you know how to use a simple hand tools - you can easy do it yourself. - The part number for the bake igniter AP2150412 - Here are the break down diagrams for the Tappan range Model 30-3982-00-01 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Whirlpool oven slow to heat | mmorin | Oven Repair (including Ranges and Cooktops) | 0 | 01-12-2010 03:47 AM |
| Oven is slow to pre-heat | booger | Oven Repair (including Ranges and Cooktops) | 0 | 10-18-2009 07:42 PM |
| oven is slow to heat | Tony B | Oven Repair (including Ranges and Cooktops) | 0 | 09-02-2009 05:45 PM |
| oven slow to heat up | freanclr | Oven Repair (including Ranges and Cooktops) | 0 | 03-09-2009 12:43 PM |
| oven slow to heat | sugarmp21 | Oven Repair (including Ranges and Cooktops) | 0 | 02-13-2009 09:20 AM |
