The broiler element does not get hot. Before I had a chance to check the element The oven stuck on and gave an F2 code. I turned off the breaker for a few minutes and it is okay now. I realize I may have to replace the oven temp sensor.
When the oven stuck on, the broiler element got red hot, but after the reset it is not working again. When the oven control is turned to broil a click is heard and the light comes on, but no heat. Does the To8 have to be replaced or in there a relay on the board that can be replaced?
Also, I see 3 oven temp sensors ranging in price from $16 to $60. Whats the difference?
With the element good, and the control sounding okay, what should I check next?
