Discuss
Maytag electric range temperature problem
 in
I bought this range a little over a year ago. Recently, when using the oven at a temperature above 325
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag electric range temperature problem
  #1 (permalink)
Old 05-14-2009, 11:42 AM
Junior Member
AndreDW is on a distinguished road
Default Maytag electric range temperature problem
Model Number: MES5775   Brand: Maytag   Age: 1 - 5 years
I bought this range a little over a year ago. Recently, when using the oven at a temperature above 325 degrees the oven will reach the desired temp then cut off a few minutes later. When it cuts off, it beeps with two quick beeps, flashes "bake" continuously and the oven light goes out for a moment or two. I am unable to use the oven until the oven light starts working again.
We don't experience this every time we use the oven.
The control board has been replaced twice so I don't think it is the cause of the problem.
We don't experience this problem when the temperature is set at or below 325 degrees.
Thanks in advance
AndreDW
Related Models
Maytag MES5775BAB RANGE- S/I STD ELE
Maytag MES5775BAB19 30" Slide-In Electric Range
Maytag MES5775BAF RANGE- S/I STD ELE
Maytag MES5775BAF19 30" Slide-In Electric Range
Maytag MES5775BAN RANGE- S/I STD ELE
Maytag MES5775BAN20 30" SLIDE-IN ELECTRIC RANGE
Maytag MES5775BAS RANGE- S/I STD ELE
Maytag MES5775BAS19 30" Slide-In Electric Range
Maytag MES5775BCB RANGE- F/S STD ELE
Maytag MES5775BCB20 30" SLIDE- ELECTRIC RANGE
Maytag MES5775BCF RANGE- F/S STD ELE
Maytag MES5775BCW RANGE- F/S STD ELE
Maytag MES5775BCW20 30" SLIDE- ELECTRIC RANGE
Maytag MES5870AAA RANGE- S/C S/I ELE
Maytag MES5870AAB RANGE- S/C S/I ELE
Maytag MES5870AAC RANGE- S/C S/I ELE
Maytag MES5870AAQ RANGE- S/C S/I ELE
Maytag MES5870AAW RANGE- S/C S/I ELE
Maytag MES5870ACB RANGE- S/C S/I ELE
Maytag MES5870ACW RANGE- S/C S/I ELE
Maytag MES5875BAB RANGE- S/I STD ELE
Maytag MES5875BAB19 30" Slide-In Electric Range
Maytag MES5875BAF RANGE- S/I STD ELE
Maytag MES5875BAF19 30" Slide-In Electric Range
Maytag MES5875BAN RANGE- S/I STD ELE
Maytag MES5875BAN20 30" Slide-In Electric Range
Maytag MES5875BAS RANGE- S/I STD ELE
Maytag MES5875BAS20 30" Slide-In Electric Range
Maytag MES5875BCB RANGE- F/S STD ELE
Maytag MES5875BCB20 30" Slide-In Electric Range
Maytag MES5875BCF RANGE- F/S STD ELE
Maytag MES5875BCF20 30" Slide-In Electric Range
Maytag MES5875BCS RANGE- F/S STD ELE
Maytag MES5875BCS20 30" Slide-In Electric Range
Maytag MES5875BCW RANGE- F/S STD ELE
Maytag MES5875BCW20 30" Slide-In Electric Range
Maytag MET3800TW0 WASHER/DRYER LAUNDRY SYSTEM
Maytag MET3800TW1 WASHER/DRYER LAUNDRY SYSTEM
Maytag MET3800TW2 WASHER/DRYER LAUNDRY SYSTEM
Maytag MET8665XB00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE NON-CONVECT
Maytag MET8665XS00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE NON-CONVECT
Maytag MET8665XW00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE NON-CONVECT
Maytag MET8775XB00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8775XS00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8775XW00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8885XB00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8885XS00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MET8885XW00 30" ELECTRIC FREESTANDING SELF CLEAN RANGE CONVECTION
Maytag MEV41F-10P MWAVE- CNTRTP / STAND ALONE
Maytag MEW5527BAB WALLOVEN- S/C ELE
Maytag MEW5527BAW WALLOVEN- S/C ELE
Maytag MEW5527DDB WALLOVEN- S/C ELE
Maytag MEW5527DDB16 27" BUILT-IN ELECTRIC OVEN SELF-CLEAN
Maytag MEW5527DDS10 27" BUILT-IN ELECTRIC OVEN SELF-CLEAN
Maytag MEW5527DDW WALLOVEN- S/C ELE
Maytag MEW5527DDW16 27" BUILT-IN ELECTRIC OVEN SELF-CLEAN
Maytag MEW5530AAB WALLOVEN- S/C ELE
Maytag MEW5530AAW WALLOVEN- S/C ELE
Maytag MEW5530ACB WALLOVEN- S/C ELE
Maytag MEW5530ACW WALLOVEN- S/C ELE
Maytag MEW5530BAB WALLOVEN- S/C ELE
Maytag MEW5530BAW WALLOVEN- S/C ELE
Maytag MEW5530BCB WALLOVEN- S/C ELE
Maytag MEW5530BCW WALLOVEN- S/C ELE
Maytag MEW5530DDB WALLOVEN- S/C ELE
Maytag MEW5530DDB17 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5530DDB18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5530DDS10 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5530DDW WALLOVEN- S/C ELE
Maytag MEW5530DDW18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW5627BAB WALLOVEN- S/C ELE
Maytag MEW5627BAW WALLOVEN- S/C ELE
Maytag MEW5627DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5627DDB16 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5627DDS10 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEA
Maytag MEW5627DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5627DDW16 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5630BAB WALLOVEN- S/C ELE
Maytag MEW5630BAW WALLOVEN- S/C ELE
Maytag MEW5630DDB WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5630DDB17 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5630DDS10 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW5630DDW WALLOVEN-S/C DBL OVEN ELE
Maytag MEW5630DDW18 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN
Maytag MEW6527BAB WALLOVEN- S/C ELE
Maytag MEW6527BAC WALLOVEN- S/C ELE
Maytag MEW6527BAQ WALLOVEN- S/C ELE
Maytag MEW6527BAS WALLOVEN- S/C ELE
Maytag MEW6527BAW WALLOVEN- S/C ELE
Maytag MEW6527CAS WALLOVEN- S/C ELE
Maytag MEW6527DDB WALLOVEN- S/C ELE
Maytag MEW6527DDB18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6527DDQ WALLOVEN- S/C ELE
Maytag MEW6527DDS WALLOVEN- S/C ELE
Maytag MEW6527DDS18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6527DDW WALLOVEN- S/C ELE
Maytag MEW6527DDW18 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag MEW6530AAB WALLOVEN- S/C ELE
Maytag MEW6530AAW WALLOVEN- S/C ELE
Maytag MEW6530ACB WALLOVEN- S/C ELE
Maytag MEW6530ACW WALLOVEN- S/C ELE
Maytag MEW6530BAB WALLOVEN- S/C ELE
Maytag MEW6530BAC WALLOVEN- S/C ELE
Maytag MEW6530BAQ WALLOVEN- S/C ELE
Maytag MEW6530BAS WALLOVEN- S/C ELE
Maytag MEW6530BAW WALLOVEN- S/C ELE
Maytag MEW6530BCB WALLOVEN- S/C ELE
Maytag MEW6530BCW WALLOVEN- S/C ELE
Maytag MEW6530CAS WALLOVEN- S/C ELE
Maytag MEW6530DDB WALLOVEN- S/C ELE
Maytag MEW6530DDB19 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6530DDQ WALLOVEN- S/C ELE
Maytag MEW6530DDS WALLOVEN- S/C ELE
Maytag MEW6530DDS19 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6530DDW WALLOVEN- S/C ELE
Maytag MEW6530DDW20 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN NON-CONVECT
Maytag MEW6627BAB WALLOVEN- S/C ELE
Maytag MEW6627BAC WALLOVEN- S/C ELE
Maytag MEW6627BAQ WALLOVEN- S/C ELE
Maytag MEW6627BAS WALLOVEN- S/C ELE
  #2 (permalink)
Old 05-14-2009, 06:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by AndreDW View Post
...The control board has been replaced twice...
Hi Andrew,
Did it fix the problem, even temporary? Who replaced the control board?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-15-2009, 05:47 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi Andrew,
Each time the control board was replaced we experienced the problem the same day. Each time it was replaced by a repairman. The repairman thought the first replaced board was faulty and ordered the second one.
AndreDW
  #4 (permalink)
Old 05-15-2009, 06:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Such problem is very hard to diagnose. If the board has been replaced while the range was under the warranty and it did not solve the problem then you have to talk to the Maytag authorities. If they can not fix it then they should give you a new range. This is not an easy task and you have to be very hard with them.
__________________
  #5 (permalink)
Old 05-15-2009, 06:24 PM
Junior Member
Default
Thanks Gene
  #6 (permalink)
Old 05-15-2009, 06:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire electric range temperature fluctuations faisalmali Oven Repair (including Ranges and Cooktops) 2 11-26-2009 09:58 AM
Maytag Performa Electric Range Smoothtop MollyGolly Oven Repair (including Ranges and Cooktops) 0 10-27-2009 05:13 PM
Frigidaire electric smoothtop range - element problem digglife Oven Repair (including Ranges and Cooktops) 2 09-04-2009 03:24 PM
Electric Range oven and clock problem lancair90 Oven Repair (including Ranges and Cooktops) 0 03-18-2009 08:32 AM
maytag electric range pelder Oven Repair (including Ranges and Cooktops) 2 01-26-2009 07:57 AM
