Is there a fuse in this type stove...the stove is plugged in but the stove nor the oven will work
Here are your parts Replacement parts for WHIRLPOOL RF365PXYW2 ELECTRIC RANGE | AppliancePartsPros.comSee the attachment for the wiring diagram. There is not a fuse/breaker in the unit so odds are there is a problem with the power getting to the unit. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. [COLOR="Red"] Be careful as 240 volts is lethal !!![/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
