Discuss
Jennaire died
 in
Tonight while using the oven our stove totally died and began making a buzzing noise which I traced to one
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jennaire died
  #1 (permalink)
Old 10-29-2011, 07:38 PM
Junior Member
dhamblet is on a distinguished road
Default Jennaire died
Model Number: SVD48600P   Brand: Jenn-Air   Age: More than 10 years
Tonight while using the oven our stove totally died and began making a buzzing noise which I traced to one or both of the relays on the Auxiliary Relay Board behind the rear cover. The front panel -- all lights and controls are dead as are both oven elements. But the upper cooling fan which cools the space between the oven and the cooktop is on. I am getting good power from both sides of the line. I have removed the Aux Relay Board and included a pic of it. I cannot find this part on your website and I have not conclusively determined if it is the problem or it is reacting to some other problem. Can you help?
Ads By Google
Related Models
Jenn-Air SVD48600P Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PT Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600W Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600WC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVE47100B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
  #2 (permalink)
Old 10-30-2011, 07:06 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for JENN-AIR SVD48600P RANGE-S/C S/I GAS & ELEC DUEL FUEL | AppliancePartsPros.com
The relay board is Item 29 in Section 3.
Could be something is dropping the supply voltage.
Looks like all it does is control the door lock motor and the fan.
try running the unit with it disconnected just make sure that the wires cannot short to any thing. Perhaps tape them.
Buzzing is often an indication of low power to the relay coil.
Looks like they are 9 volt relays but hard to tell from your picture.
The wiring diagram included in the parts is not very good but I cannot find a better one.
Looks like the transformer that powers the control board is hard wired across the line (L2 to Neutral) perhaps there is a problem with it.
Does the oven light work as it is wired in parallel with the transformer.
__________________
  #3 (permalink)
Old 10-30-2011, 09:27 AM
Junior Member
Default
Quote:
Originally Posted by denman View Post
oven light works but that is the only thing that does other than the ignitors for the gas burners. I suspect you are correct and the relay board is probably ok but getting low voltage. They are in fact 9V relays and voltage to the primary sides of them is under 2 volts but is that actuated or unactuated? Voltage to the secondaries is 125. I will dig into it further to see if I can locate the main control board. Thank you.
Dennis
  #4 (permalink)
Old 10-30-2011, 10:12 AM
Junior Member
Default
I have the upper control panel open and exposed now. I checked the voltages on the relay and it seems ok. VOltages are
pins 1-2 122VAC
11-12 9.7
11-13 19.4
9-10 4.1
Suggestions????
  #5 (permalink)
Old 10-30-2011, 11:02 AM
Junior Member
Default
I suspect the upper Control Panel is defective. Is there a procedure to confirm this?
  #6 (permalink)
Old 10-30-2011, 01:47 PM
Senior Expert
APP Volunteer
Default
Sounds like it is getting the correct power and will not light up so I would say it is toast.
There may be some diagnostics but I cannot find a manual for this unit.
I will do some more searching and if I can find one I will post it for you.
__________________
  #7 (permalink)
Old 10-30-2011, 01:58 PM
Senior Expert
APP Volunteer
Default
Well that did not take long here is a manual
Download SVD48600.pdf
__________________
  #8 (permalink)
Old 10-30-2011, 04:44 PM
Junior Member
Default
Thanks. Based on test voltages from the manual I think it is the Control Panel for sure and am ordering a new one. Cross your fingers.
Thanks again,
Dennis
  #9 (permalink)
Old 11-02-2011, 05:14 PM
Junior Member
Default
Replaced the control panel today and everything is back to normal. Only had one screw left over 8 ) but I think it was already under the stove.
  #10 (permalink)
Old 11-03-2011, 02:11 AM
Senior Expert
APP Volunteer
Default
Glad to hear that you are up and running.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
She just died... mshep01 Refrigerator & Freezer Repair 5 09-01-2011 05:15 AM
Help Installing Jennaire left rear element switch- sherol Oven Repair (including Ranges and Cooktops) 0 03-12-2011 06:40 AM
JennAire Oven mklayers Oven Repair (including Ranges and Cooktops) 10 05-22-2010 07:14 AM
F3 error on Jennaire yorkiemom Oven Repair (including Ranges and Cooktops) 1 09-24-2009 09:06 AM
