mark763
#1 Posted : Saturday, October 29, 2011 8:37:24 AM(UTC)
mark763
I completed a self clean and my oven started giving me the F2 E1 error. I have read elsewhere on these forums that cleaning contacts and inspecting the ribbon for cracks, along with repair using silver pen has worked to fix the problem.
I am unable to access the control panel. I have removed the 6 screws below the panel and removed the knobs but I can only lift up the panel 1 inch. I have tried to slide it out but it only moves a very small amount on one end.
If anyone can advise on how to remove that would be very helpful. thanks,
Photos of my progress below:
[/URL]https://lh4.googleusercontent.co...KpMmVM/s800/IMG_1439.JPG
thanks for the help.
mark763
#2 Posted : Sunday, October 30, 2011 7:38:34 AM(UTC)
mark763
Finally figured it out, I had to lift up the panel and rotate it out of the hinge with the glass top.
I inspected the control panel, all connections wiring and the ribbons but did not see and defects, burn marks, etc. I ended up just taking out all of the connections and re-attaching them.
So far so good, no F2 E1 error, was able to run the oven for an hour at 400 degrees with no issues. Hopefully it was just a loose connection that was caused by the heat of the self clean.
Mark.
