Discuss
No power cooktop or oven
 in
The stove in my rental went out. It is a whirlpool brand. There is no power to the stovetop or
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No power cooktop or oven
  #1 (permalink)
Old 12-10-2007, 04:44 PM
SandyT SandyT is offline
Junior Member
SandyT is on a distinguished road
Default No power cooktop or oven
Model Number: ?   Brand: Whirlpool   Age: 5 - 10 years
The stove in my rental went out. It is a whirlpool brand. There is no power to the stovetop or the oven. When I turn on a burner then I show power (the clock shows up) I have held the reset button for 5 seconds and it changes from PO to EO and still no heat. WThen when I turn the burrner to the off position the clock goes out.
The guy across the street said he would "throw a couple of bucks my way" to buy the stove which leads me to believe it might be something simple (switch or something) Anybody....help...please...Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-11-2007, 01:31 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to provide the most accurate advise I need the complete model number of the unit.
If this is a counter top unit, then the name plate should be on the bottom panel (from inside of the cabinet) or under the top panel (if there is not a glass top).
If this a freestanding unit, then the name plate could be on the door frame, on the frame behind the bottom drawer or under the top panel.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-12-2007, 05:43 PM
Junior Member
Default
OK, I feel really stupid! All I had to do was flip the breaker switch!
My tenants told me they flipped the breaker and the stove still didn't work. First mistake! I should have checked for myself! The odd thing was the power (clock) came on when I turned the burner switch on (but not the burner, no heat) There's a good reason for this too! In the breaker box there are 2 breakers switches for the stove. They had only reset one.
Thank you for trying to figure this one out and I have now graduated from the school of great ignorance and hard knocks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
power to oven rseavey Oven Repair (including Ranges and Cooktops) 0 12-05-2007 08:31 AM
whirlpool oven small explosions, cooktop ignitor nannygoat Oven Repair (including Ranges and Cooktops) 3 10-30-2007 11:23 AM
no power to gas oven ignitor-help with model # coslickr Oven Repair (including Ranges and Cooktops) 0 10-20-2007 03:22 PM
Ceramic Cooktop slide-in oven/stove EVdelRsoario Oven Repair (including Ranges and Cooktops) 1 09-19-2007 01:48 PM
Whirlpool Elect Double Oven no power lfein Oven Repair (including Ranges and Cooktops) 1 09-12-2007 11:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
