Discuss
Oven
 in
My Oven Will Not Ignite. We Have Order From U And Installed The Oven Igniter. It Did Not Solve The
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven
  #1 (permalink)
Old 12-10-2007, 01:20 PM
Vernitte Vernitte is offline
Junior Member
Vernitte is on a distinguished road
Default Oven
Model Number: LGB336GET2AD   Brand: -other-   Age: More than 10 years
My Oven Will Not Ignite. We Have Order From U And Installed The Oven Igniter. It Did Not Solve The Problem.
What Should Be Our Next Step . We Thought Maybe The Spark Module Might Be Bad. It Is Located Behind The Top Panel Behand The Dial That Turns The Temp To What U Need Or To Broil Or Clean.
Could U Please Advise What Our Problem Might Be. Thanks So Much
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-10-2007, 06:55 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check if 120V is coming to the igniter when the thermostat calls for the bake.
Make sure the both knobs are in the right position and are not broken.
Post your findings, please.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
