Discuss
oven not working
 in
went to preheat oven and there's no heat, broiler is working though can you give me some insight cuold
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven not working
  #1 (permalink)
Old 12-09-2007, 06:46 PM
wilma wilma is offline
Junior Member
wilma is on a distinguished road
Default oven not working
Model Number: agr5715qds   Brand: Amana   Age: 1 - 5 years
went to preheat oven and there's no heat, broiler is working though can you give me some insight cuold this be the igniter in the lower part of the oven just needs replaced and how much is the part
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-10-2007, 02:27 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Unplug the bake igniter and check for 120V coming to the igniter while the oven is set on Bake.
If there is 120V then the igniter has to be replaced.
If there is no 120V then the control board is bad and has to be replaced.
- The part number for the bake igniter AP3455537
To find the right part number for the control board I need the serial number of the range.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-29-2007, 06:16 PM
lorriehenry lorriehenry is offline
Junior Member
lorriehenry is on a distinguished road
Default Oven Not Working
I have a GE JGBP30 range. Its gas, the burners work on the top, the broiler works fine but oven will not lite. Worked just fine yesterday.. please help? Thanks lorrie
  #4 (permalink)
Old 12-29-2007, 06:18 PM
Junior Member
GE JGBP30 gas range. The burners work on the top, the broiler works also. We used the oven yesterday and it worked fine. Now it will not lite? Please help could it be the igniter and how would we test it!
  #5 (permalink)
Old 12-30-2007, 09:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is the igniter.
You can read the post on top of yours to get the test instructions.
In order to find the right part number for the igniter (or other parts) I need the complete model number of the range.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven not working-Stovetop working Jame Oven Repair (including Ranges and Cooktops) 8 10-08-2008 10:08 AM
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 6 09-18-2008 10:03 AM
Oven not working wmenke Oven Repair (including Ranges and Cooktops) 1 11-25-2007 07:00 AM
Double Oven--Main oven not working bccavanaugh Oven Repair (including Ranges and Cooktops) 1 09-15-2007 11:22 PM
Oven Not Working strahmdonna Oven Repair (including Ranges and Cooktops) 1 08-30-2007 08:41 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
