| » recieving F3 E4 error code on Range |
Model Number: gr470lxmc Brand: Whirlpool Age: 5 - 10 years
We just replaced our Temp Sensor and still getting the same error. We bought our replacement through your parts, Customer service adv to contact the forum and ask if there is any other cause that this error will still be coming up even after we installed the Temp Sensor...the oven continues to shut off while we are trying to make dinner....thank you
Did you check the old sensor with a meter before replacing it? Check it at the control board as they use a jumper from the upper sensor to the lower sensor to connect in P4-1 and perhaps this wire is bad. If not you may want to check the new one. Here is info on it, see 7, 8, 20 and 21. http://www.applianceaid.com/elecrange.html If OK check where the sensor attaches to the control board. You are looking for a bad connection or solder joint on the board re: the circuit trails that go to the sensor. A cold/bad solder joint is often a duller gray or has pin holes. Also wiggle the connector on the board while watching the soldered side if the connector leg moves re-solder it in. If you cannot find anything then I would replace the control board.
__________________
| Display Modes | |
| error code PF when i try to use my range | MikkiJ24 | Oven Repair (including Ranges and Cooktops) | 0 | 10-10-2010 03:18 PM |
| Range Error Code | JameyT | Oven Repair (including Ranges and Cooktops) | 0 | 08-28-2009 08:40 AM |
| Range error code | mattress68 | Oven Repair (including Ranges and Cooktops) | 0 | 05-03-2009 03:33 PM |
| GE Gas Range Error Code F1 | RiverFisher | Oven Repair (including Ranges and Cooktops) | 1 | 01-09-2009 07:42 AM |
| WP Range Error Code E2/F3 | go2geye | Oven Repair (including Ranges and Cooktops) | 1 | 04-24-2008 10:05 PM |
