When You Turn The Top Burner On It Will Ignite Then It Will Slowly Burn Out, Shut The Burner Off Waite About 60 Seconds And Reignite And It Will Be Fine. Is This A Stove Problem, Or Is It A Gas Supply Problem? Is The Regulator Bad? Is There An Internal Gas Valve? The System Is Lpg. Thanks In Advance.......
