Oven was in use at correct temp, when suddenly a pop and then smoke from the electric oven control area in center of panel. Digital readout is still working and showing whatever temp you select, but it only gives a clicking sound when trying to turn it on. Could this be a EOC or can it be a relay or switch in EOC?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Thank you for taking the time to reply. I will try to look for evident damage.
