Unit lost all power to control panel and oven door malfunctioned in the locked position during a self cleaning operation. Wife states she heard some rattling noise during the self clean which stopped.:mad:
Repair tech: Discovered a blown fuse going to the control panel and did a work around to restore power to the panel. All fuctions work, blower motor seems to work ok, convection fan ok but no heat to the oven. He quoted the following parts 815174-Fuse replacement and 9759242-thermostat replacement. I could not find these part numbers in the Appliance Parts Pro data base. Are these standard part numbers for Kitchenaid and do you have them in stock. Please note the fuse attaches to the wiring harness behind the contol panel.
Thank you. Rockie:confused:
