Discuss
No power to Oven after Power Loss to home
 in
Weird problem after the weird storm that knocked the Cowboys Bubble facility last week the stome hit my area about
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No power to Oven after Power Loss to home
  #1 (permalink)
Old 05-06-2009, 11:14 AM
Junior Member
mac21 is on a distinguished road
Default No power to Oven after Power Loss to home
Model Number: RBD305PDS14   Brand: Whirlpool   Age: 1 - 5 years
Weird problem after the weird storm that knocked the Cowboys Bubble facility last week the stome hit my area about 20 minutes before all my lights went out but everything came back on except my oven none of the keypad buttons work no time clock no oven lights just dead I checked the breakers and all were fine. I am wondering if this spike damaged my control panel?? Does anyone else have any tips or tricks to get this unit back on?
Ads By Google
Related Models
Whirlpool RBD305PDS14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDS15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT11
Whirlpool RBD305PDT12
Whirlpool RBD305PDT13
Whirlpool RBD305PDT14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD306PDB1
Whirlpool RBD306PDB10
Whirlpool RBD306PDB11
Whirlpool RBD306PDB12
Whirlpool RBD306PDB13
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
Whirlpool RBD306PDB7
Whirlpool RBD306PDB8
Whirlpool RBD306PDB9
Whirlpool RBD306PDQ1
Whirlpool RBD306PDQ10
Whirlpool RBD306PDQ11
Whirlpool RBD306PDQ12
Whirlpool RBD306PDQ13
Whirlpool RBD306PDQ14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ2
Whirlpool RBD306PDQ4
Whirlpool RBD306PDQ6
Whirlpool RBD306PDQ7
Whirlpool RBD306PDQ8
Whirlpool RBD306PDQ9
Whirlpool RBD306PDT11
Whirlpool RBD306PDT12
Whirlpool RBD306PDT13
Whirlpool RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDT15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDZ1
Whirlpool RBD306PDZ10
Whirlpool RBD306PDZ2
Whirlpool RBD306PDZ4
Whirlpool RBD306PDZ6
Whirlpool RBD306PDZ7
Whirlpool RBD306PDZ8
Whirlpool RBD306PDZ9
Whirlpool RBD307PDB1
Whirlpool RBD307PDB2
Whirlpool RBD307PDQ1
Whirlpool RBD307PDQ2
Whirlpool RBD307PDQ4
Maytag RBE170PA  Ref - Top Mount
Maytag RBE170PW  Ref - Top Mount
Maytag RBE170TA Ref - Top Mount
Maytag RBE170TM Ref - Top Mount
Maytag RBE170TV Ref - Top Mount
Maytag RBE170TW Ref - Top Mount
Maytag RBE17KA-0A  Ref - Top Mount
Maytag RBE17KN-0A  Ref - Top Mount
Maytag RBE193PA  Ref - Top Mount
Maytag RBE193PW  Ref - Top Mount
Maytag RBE193TA Ref - Top Mount
Maytag RBE193TM Ref - Top Mount
Maytag RBE193TV Ref - Top Mount
Maytag RBE193TW Ref - Top Mount
Maytag RBE19KA-3A  Ref - Top Mount
Maytag RBE19KN-3A  Ref - Top Mount
Maytag RBE19KY-3A  Ref - Top Mount
Maytag RBE214AFM Ref - Top Mount
Maytag RBE214AFV Ref - Top Mount
Maytag RBE214RFA  Ref - Top Mount
Maytag RBE214RFV  Ref - Top Mount
Maytag RBE214TFA Ref - Top Mount
Maytag RBE214TFM Ref - Top Mount
Maytag RBE214TFV Ref - Top Mount
Maytag RBE21KA-4AF  Ref - Top Mount
Maytag RBE21KA4AF  Ref - Top Mount
Maytag RBE21KN-4AF  Ref - Top Mount
Maytag RBE21KN4AF  Ref - Top Mount
Frigidaire RBF136CL Frg(v1) / Electric Cooktop
Frigidaire RBF139CE1 Frg(v1) / Cooktop
Frigidaire RBF139CE2 Frg(v1) / Cooktop
Amana RBG322T Mwave - Cntrtp / Stand Alone
Amana RBG322T1 Mwave - Cntrtp / Stand Alone
Amana RBG358P Mwave - Cntrtp / Stand Alone
Amana RBG622T Mwave - Cntrtp / Stand Alone
Amana RBG635T Mwave - Cntrtp / Stand Alone
Frigidaire RBGF119E1 BLACK Frg(v8) / Electric Cooktops and Control Box
Frigidaire RBGF119EL1 Frg(v7) / Electric Cooktops and Control Box
Frigidaire RBGF119EW1 Frg(v6) / Electric Cooktops and Control Box
Amana RBK22AA0 Range - S/i Std Gas
Amana RBK22AA093M Range - S/i Std Gas
Amana RBK22AA5 Range - S/i Std Gas
Amana RBK22AAL Range - S/c S/i Ddraft Gas
Amana RBK22AAW Range - S/c S/i Ddraft Gas
Amana RBK24AA Range - S/i Std Gas
Amana RBK24AA0 Range - S/i Std Gas
Amana RBK24AA093M Range - S/i Std Gas
Amana RBK24AA5 Range - S/i Std Gas
Amana RBK24AAL Range - S/c S/i Ddraft Gas
Amana RBK24AAW Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 05-06-2009, 12:00 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL RBD305PDS14 | AppliancePartsPros.com
Here is the tech sheet
https://www.servicematters.com/docs/...%208302068.pdf
If you just looked at the breakers try turning them off/on slowly a couple times. Breakers can drop out without actually tripping.
Next would be to check at the unit with a meter to confirm that it is getting the correct voltage.
Next it could be the Control Thermal Fuse is blown. Unplug the unit, remove the fuse and check it with a meter. Should be 0 ohms.
BE CAREFUL 240 volts is lethal !!!
__________________
  #3 (permalink)
Old 05-06-2009, 01:05 PM
Junior Member
Default
Thanks for the quick reply and info I will check fuses and update you thanks again
  #4 (permalink)
Old 05-16-2009, 11:27 AM
Junior Member
Default
Denman
I checked for main breaker looks lfine and is pumping 240 to the oven. After looking at your tech sheet the one in the oven differs a little this one does not have a control panel fuse. Will the thermal shutdown fuse also cause the over to show absolute NO POWER? I tapped off the control board with my meter and I am getting 240 going into the xformer part of the control board now I am starting to assume that it looks to be a bad control board. I still have no display no light nothing at all
What do you think??
  #5 (permalink)
Old 05-16-2009, 11:42 AM
Junior Member
bryan green is on a distinguished road
Default
I have the same problem also after a storm power loss. every things the same as your oven except my oven beeps now. but still no lights showing on the control panel.
  #6 (permalink)
Old 05-16-2009, 12:08 PM
Junior Member
Default
I don't even have a beep nothing D.O.A. I am looking for a place to order the control panel i found some for 159ish and I am waiting for Monday to call whirlpool and see what they charge for it
  #7 (permalink)
Old 05-16-2009, 01:19 PM
Junior Member
Default
Please tell me where you got it for that price ,I have a feeling I'm going to need one Mac.
  #8 (permalink)
Old 06-09-2009, 05:43 PM
Junior Member
Default
to Denman or anyone that can help
I purchased the part that subbed my control board and it arrived today but it looks totally different can someone help me out in the right direction??
Below is the picture of the original board in the oven
And here is the board that was sent to me
Not even close but it comes up as the sub for the original if anyone can help out please let me know
  #9 (permalink)
Old 06-10-2009, 08:36 AM
Senior Expert
APP Volunteer
Default
Do not think I can be of much help here.
Double check your Model Number.
Note there is always the possibility that the Model Number tag is incorrect.
I looked up the board you received and it is the same as the one shown on AppliancePartsPros so I assume it is the correct one for the listed model.
Check the keypad on AppliancePartsPros, is it the same as yours?
Is yours a single or double oven?
I did look up the tech sheets with a RBD305 prefix and did find some with a different control board but it still did not exactly match yours.
The below is for a RBD305PDQ1
Tech Sheet
https://www.servicematters.com/docs/...%204450808.pdf
APP's parts breakdown
Replacement parts for WHIRLPOOL RBD305PDQ1 | AppliancePartsPros.com
You said you see 240 volts at the transformer on the board, this seems to indicate that you do not have the external transformer which is shown on the tech sheet for your listed model. The board will not run without this as it powers the electronics, I think!!
On other point I noticed on your earlier post you said you had the 240 volts but did you also have the 120 volts which is also required. If Neutral has dropped out then you will not get the 120.
I am also going to post this in the tech section with a little luck someone has run into this situation.
__________________
  #10 (permalink)
Old 06-16-2009, 08:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm afraid there is something wrong with these parts. The old board shown on the picture has a low voltage transformer and the new one does not. The wiring diagram for the model number RBD305PDS14 shows the low voltage transformer outside the control board. There is no way the manufacturer made such serious changes. You have to verify everything and repost the information.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool microwave power loss alikatmack Microwave Repair 0 01-11-2010 06:23 PM
huge power draw on home circuit lugnut Heating, Ventilation, and Air Conditioning (HVAC) 0 07-23-2008 06:33 PM
No Control Power, No Power in Stove keith ormsby Oven Repair (including Ranges and Cooktops) 1 01-19-2008 06:47 PM
loss of power / wont start lt3 Dryer Repair 7 01-10-2008 09:21 AM
