I've just replaced the potentiometer with the kit recommended. However, the pots and controller numbers do not match the instructions. My existing simmer controller box is SQ002-H, and the replacement is SQ003-HB. The existing pots snap in and are vertically oriented, while the replacements are canted to the right. The numbers on the existing pots 3772/4 & 04-0076-.0004. Are these replacement correct for my range?\ Thanks, SftyMan
