Just wanted to get an opinion on this. Broil ignites OK, but oven won't come to temp (ie. 400) when set on bake. I would guess maybe the igniter is the problem, but the broiler works OK. Is there anything specific for me to check out? Is is possibly another part different than the igniter?
Thanks.
Jim
Jim,
Does it heat on Bake at all? How long takes for the Bake burner to light up since you turn the control on?
Gene,
Thanks for getting back to me. In the meantime I followed up on all the previous threads related to my topic. Once I removed the bake oven igniter it was obvious that was the problem and there was definitely no continuity. Replaced the igniter and I'm back up and running again.
Great site! Thanks.
Jim
You are welcome. We are glad you were able to fix it.
oven wont lite and broiler works ok is it the electronic ign or something else smelling gas and getting little heat from oven a Frigidaire model glgfs66abd
does not get very bright (ign Lite) and can smell gas
Martha,
Sounds like the igniter is too weak. If you need the correct part number then post the complete model number of the oven.
