dave100
#1 Posted : Monday, May 4, 2009 12:12:14 PM(UTC)
dave100
Over the last five years I have replace the grill igniter four times. The first three time the igniter worked for about a year. This time I replaced the igniter and the igniter did not heat up. I ordered the grill valve for this model and the new igniter will still not come on. I have on back order the grill harness part that slips onto the grill knob shaft. Why won't the grill work???? I traced the wiring back to a split that provides voltage to one of the stove burner that lights just fine. I am frustrated.
:confused:
#2 Posted : Monday, May 4, 2009 7:32:28 PM(UTC)
Looks like there is no power to the grill igniter. According to the wiring diagram there are only three components - the igniter, the valve and the valve switch. If the igniter and the valve are new then the switch is only left. Appliance Parts Pros has it in stock and you can have it Wednesday.
- The part number for the grill switch harness is AP3084039
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KGCP482KSS0 | AppliancePartsPros.com
