Discuss
electric Over will not turn off
 in
The over would not turn off. The element got white hot and finally burned out. First of all, is there
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » electric Over will not turn off
  #1 (permalink)
Old 05-04-2009, 09:48 AM
Junior Member
tbogan is on a distinguished road
Default electric Over will not turn off
Brand: Maytag   Age: 5 - 10 years
The over would not turn off. The element got white hot and finally burned out. First of all, is there an electrical schematic available for these electric ranges?
How is the on-off controlled? Is it simply a contactor or is it by means of SCR's or triacs? I would assume that since it did not turn off it either did not get a signal to turn off of what ever controls the on-ff is shorted.
Thanks,
Tom
Ads By Google
  #2 (permalink)
Old 05-04-2009, 02:28 PM
Junior Member
Ex-SearsTech is on a distinguished road
Default
The 2 times I have seen this it was the main control board had a shorted relay If I remember correctly.
  #3 (permalink)
Old 05-04-2009, 03:20 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Need a Model Number to have any hope of finding a wiring diagram.
Most stoves just use a relay.
Often the contacts weld together but can be other causes.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Electric Range won't get hot unless you turn it way up axrowland Oven Repair (including Ranges and Cooktops) 3 01-11-2010 07:58 AM
electric oven will not turn on hotlen Oven Repair (including Ranges and Cooktops) 0 09-21-2009 03:20 PM
electric Over will not turn off tbogan Oven Repair (including Ranges and Cooktops) 0 05-04-2009 09:46 AM
Electric Ovev not turn off tbogan Oven Repair (including Ranges and Cooktops) 0 05-04-2009 09:37 AM
electric dryer drum won't turn dlt1520 Dryer Repair 0 02-10-2008 07:16 AM
