Discuss
Oven not heating properly
 in
I own a Whirlpool range that is 3 yrs. old. I noticed the other day I went to fix a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven not heating properly
  #1 (permalink)
Old 08-03-2007, 02:38 PM
harry-homeowner harry-homeowner is offline
Junior Member
harry-homeowner is on a distinguished road
Post Oven not heating properly
Model Number: SF303PEK02   Brand: Whirlpool   Age: 1 - 5 years
I own a Whirlpool range that is 3 yrs. old. I noticed the other day I went to fix a meal, I preheated the oven, and put the food in the oven. I waited 14mins per package directions, when I went to get the food out the oven was not even hot; however, the stove works fine.
Is it the thermocoupler or the igniter? Is that the proper part name?
Harry -homeowner
Related Models
Whirlpool SF303PEKQ0
Whirlpool SF303PEKQ1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEKQ2 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEKT0
Whirlpool SF303PEKT1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEKW0
Whirlpool SF303PEKW1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEKW2 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEPQ0 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEPQ1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEPQ2 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEPQ3 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF3040SRW0
Whirlpool SF3040SRW1
Whirlpool SF3040SRW2
Whirlpool SF3040SRW3
Whirlpool SF3040SRW4
Whirlpool SF3040SRW5
Whirlpool SF3040SRW6
Whirlpool SF3040SWW0
Whirlpool SF3048EPW0
Whirlpool SF304BEPW0
Whirlpool SF304BSAG0
Whirlpool SF304BSAN0
Whirlpool SF304BSAN1
Whirlpool SF304BSAW0
Whirlpool SF304BSAW1
Whirlpool SF304BSPW0
Whirlpool SF304BSWW0
Whirlpool SF304BSWW1
Whirlpool SF304BSYG0
Whirlpool SF304BSYG1
Whirlpool SF304BSYN0
Whirlpool SF304BSYN1
Whirlpool SF304BSYW0
Whirlpool SF304BSYW1
Whirlpool SF304PEEN0
Whirlpool SF304PEEQ0
Whirlpool SF304PEEW0
Whirlpool SF305BEWN0
Whirlpool SF305BEWN1
Whirlpool SF305BEWQ0
Whirlpool SF305BEWQ1
Whirlpool SF305BEWW0
Whirlpool SF305BEWW1
Whirlpool SF305BSWN0
Whirlpool SF305BSWN1
Whirlpool SF305BSWW0
Whirlpool SF305BSWW1
Whirlpool SF305EERW0
Whirlpool SF305EERW1
Whirlpool SF305EERW2
Whirlpool SF305EERW3
Whirlpool SF305EERW4
Whirlpool SF305EERW5
Whirlpool SF305ESPW0
Whirlpool SF305ESRW0
Whirlpool SF305ESRW1
Whirlpool SF305ESRW2
Whirlpool SF305ESRW3
Whirlpool SF305ESRW4
Whirlpool SF305ESRW5
Whirlpool SF305PEEN0
Whirlpool SF305PEEQ0
Whirlpool SF305PEEW0
Whirlpool SF306PEGN0
Whirlpool SF306PEGN1
Whirlpool SF306PEGQ0
Whirlpool SF306PEGQ1
Whirlpool SF306PEGW0
Whirlpool SF306PEGW1
Whirlpool SF3100EKW0
Whirlpool SF3100EPW0
Whirlpool SF3100ERW0
Whirlpool SF3100ERW1
Whirlpool SF3100ERW2
Whirlpool SF3100ERW3
Whirlpool SF3100ERW4
Whirlpool SF3100ERW5
Whirlpool SF3100ERW6
Whirlpool SF3100EWN0
Whirlpool SF3100EWN1
Whirlpool SF3100EWW0
Whirlpool SF3100EWW1
Whirlpool SF3100SKW0
Whirlpool SF3100SPW0
Whirlpool SF3100SRW0
Whirlpool SF3100SRW1
Whirlpool SF3100SRW2
Whirlpool SF3100SRW4
Whirlpool SF3100SRW5
Whirlpool SF310BEGN0
Whirlpool SF310BEGN1
Whirlpool SF310BEGN5
Whirlpool SF310BEGQ0
Whirlpool SF310BEGQ1
Whirlpool SF310BEGQ5
Whirlpool SF310BEGT5
Whirlpool SF310BEGW0
Whirlpool SF310BEGW1
Whirlpool SF310BEGW5
Whirlpool SF310PEAN0
Whirlpool SF310PEAN1
Whirlpool SF310PEAN2
Whirlpool SF310PEAQ0
Whirlpool SF310PEAQ1
Whirlpool SF310PEAQ2
Whirlpool SF310PEAQ3
Whirlpool SF310PEAQ4
Whirlpool SF310PEAW0
Whirlpool SF310PEAW1
Whirlpool SF310PEAW2
Whirlpool SF310PEKN0
Whirlpool SF310PEKN1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool SF310PEKQ0
Whirlpool SF310PEKQ1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool SF310PEKT0
Whirlpool SF310PEKT1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool SF310PEKV0
Whirlpool SF310PEKW0
  #2 (permalink)
Old 08-04-2007, 11:44 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Default
harry-homeowner
The first thing you do is a visual test. Turn the oven thermostat on, wait at least 30 seconds and take a look at the igniter. It should glow very bright red, almost close to white. Normal time for the igniter to open the gas burner valve and to light up the burner is between 40 second to 1 minute. If it glows red but not bright and even if it does light up the burner but it takes more than a minute, the igniter is bad and has to be replaced. If it does not glow at all, remove the power from the oven, remove the igniter wires and check for continuity between these wires. If there is no continuity, replace the igniter. The part number for the new igniter is AP3129373
If the igniter is not the issue let me know and we will proceed with further diagnosis.
Just for your references here is the break down diagrams for Whirlpool range Model SF303PEKQ0
Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker Not Working Properly cwvernon Refrigerator & Freezer Repair 1 09-02-2007 01:33 AM
oven not heating ljticeman Oven Repair (including Ranges and Cooktops) 1 08-01-2007 04:52 PM
Refer side not cooling properly, freezer okay lynbo11 Refrigerator & Freezer Repair 0 07-30-2007 08:02 AM
How to properly connect wires to capacitor? G C Washer Repair 3 07-19-2007 07:19 PM
