| » GE Profile Electric Cooktop/Range Losing Heat |
Model Number: 191D1414 Brand: GE Age: More than 10 years
Has it reached the end of its life cycle? The surface elements now take forever to boil a pot of water. All burners are similar. They seem to cycle off too often during the cooking process. Is there a chip or board or something that controls this? It did not behave this way in the past - only recently. Any suggestions appreciated. Thanks.
They are all controlled by separate switches so it would be odd that all of them would do the same thing at the same time especially when most of the time if a switch is bad it will either cause the unit to heat too much or not at all. I am not saying the switches are not your problem in fact if it were just one I would say the switch is your most likely problem. But it sounds to me like a wiring problem. Cooktop Repair Guide
Ok it is a glass-top previously it though it had regular burners. But what I said in the first post about the switches is still true. Just to be clear you say you have the problem with all of the units? The each unit has its own limiter so same thing (unlikely all went bad at once). One question does the bake and broil work ok. If it were a wiring problem as I stated before the units probably wouldn’t get red. Could you tell me how approximately how long the top burners stay red (on high and med) before cycling off? Also measure some water and let me know how much and how long it takes to boil this amount. Again if you were talking about one unit I would say the switch but all at once is unlikely.
| Display Modes | |
| How do I replace glass cooktop on a GE Profile Range | slgiles2001 | Oven Repair (including Ranges and Cooktops) | 7 | 10-31-2012 11:14 AM |
| Frigidaire Electric Range and Cooktop | bboustany | Oven Repair (including Ranges and Cooktops) | 14 | 11-18-2009 12:26 PM |
| Can Sears Repair My GE Profile Cooktop/Range? | tabcourt | Oven Repair (including Ranges and Cooktops) | 1 | 05-18-2009 05:24 PM |
| GE Profile 30" electric cooktop | marcse_ms | Oven Repair (including Ranges and Cooktops) | 4 | 10-22-2008 04:41 PM |
| Removing Maytag Electric Range Cooktop | Chryslerpetz | Oven Repair (including Ranges and Cooktops) | 3 | 01-03-2008 05:50 PM |
