I had spilt some drippings from a Turkey down into the lower area where the burner and everytime I started the oven it smoked like crazy so I decided to clean it. Ended up breaking the Ignitor which I never even saw till it was too late. Ordered a new Ignitor (which is extremely hard to find) and when it arrived the length of the wire from the ignitor to the connector on the oven wall was 6 " shorter then the original. Everyone claims I have the correct one and everything IS correct except for the length. It was suggested I just cut the wire off the old ignitor and splice it onto the new one using Ceramic Marrettes. That was a great idea until I tried to find Ceramic Marrettes and appears NOBODY has a clue what they are or where to find them. Any suggestions or do you have another idea to fix the issue ?
thanks Bruce
