I have an older model Roper Electric Range. I do lots of baking and sometimes use aluminum foil to line the base of the oven to prevent hard-to-clean spills. The last time I did this I must have accidentally disconnected the oven coil from the back of the oven. Is there a way for me to re-connect the coil?
