Discuss
Oven not heating correctly
 in
My wife was trying to use oven when the code F1 appeared. We shut the oven off and unplugged it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven not heating correctly
  #1 (permalink)
Old 12-07-2007, 07:00 PM
j_bates23 j_bates23 is offline
Junior Member
j_bates23 is on a distinguished road
Default Oven not heating correctly
Model Number: FGF354BGwe   Brand: Frigidaire   Age: 5 - 10 years
My wife was trying to use oven when the code F1 appeared. We shut the oven off and unplugged it and it, reset itself. Everything was fine I thought. Here are the symptons. I turn the thermostat to lets say 350 degrees. Push the start button. The ovens heats up for a few minutes to what I believe is the preheated tempeture of 350 degrees. Then the eoc starts to beep. And the pre heat button starts flashing. And I could hear a poofing sound. Like the sound a propane grill makes when you turn off the burners. I heard that a few times like it was turning on and off. At that point my cheese bread was finished. Oh and all the burners up top seemed to be working properly. I would appreciate any advice or suggestions.
Thanks Joe
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-07-2007, 07:26 PM
Junior Member
Default
Just tested the unit again. Everything seems to be working, no more beeping, or light flashing. But after it reaches desired temp, the gas shuts off and when it comes back on to heat again (thru the oven door) it appears to be lite, then about ten seconds later I can still hear the poofing noise. Never noticed it before I started having problems .Is this normal?
JOE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How do I put belt on correctly too much slack Stacie Dryer Repair 0 11-06-2007 01:15 PM
Gas Oven Not Heating defirechief8915 Oven Repair (including Ranges and Cooktops) 3 10-24-2007 09:26 PM
Oven keeps heating rowilson Oven Repair (including Ranges and Cooktops) 5 10-16-2007 07:05 PM
Front loader not spinning correctly Ferm2374 Washer Repair 0 08-10-2007 06:07 PM
oven not heating ljticeman Oven Repair (including Ranges and Cooktops) 1 08-01-2007 04:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
