| » F1 fault |
Model Number: MER5770AW Brand: Maytag Age: 5 - 10 years
During the self clean cycle I got a F1 fault. I changed the touchpad/clock unit and I still have the fault. What else could be the problem.
Last edited by rick17050 : 12-07-2007 at 12:49 PM. Reason: added it happened during the self cleaning |
The first thing I would check is the resistance across the oven temperature sensor. It suppose to be about 1100 Ohms at the room temperature. If the reading is incorrect, replace the oven sensor.
Also check the oven sensor wire harness for poor connections. I would recommend to eliminate the oven sensor plug, using a wire nuts instead. - The part number for the oven temperature sensor AP204836 - Here are the break down diagrams for the Maytag Range Model MER5770AAW Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
| CE Fault Code | collins66 | Washer Repair | 0 | 10-23-2007 09:02 AM |
| dishwasher fault | ian19740 | Dishwasher Repair | 0 | 10-23-2007 04:56 AM |
| F0 fault code | William | Oven Repair (including Ranges and Cooktops) | 0 | 10-10-2007 07:13 PM |
| Dishwasher - Fault Code | DIY Napton | Dishwasher Repair | 1 | 10-03-2007 05:55 PM |
| Ground Fault | DCHAR | Dishwasher Repair | 2 | 08-07-2007 07:45 AM |
