Discuss
How do I remove top burner plate to fix igniter on Thermador prg304
 in
I purchased the ring which holds the igniter in place (the old one was lost so the igniter is loose),
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How do I remove top burner plate to fix igniter on Thermador prg304
  #1 (permalink)
Old 10-11-2011, 10:39 AM
Junior Member
jljonathan is on a distinguished road
Default How do I remove top burner plate to fix igniter on Thermador prg304
Brand: -brand-   Age: Less than 1 year
I purchased the ring which holds the igniter in place (the old one was lost so the igniter is loose), but I can't get my hand in enough under the burner top to slide the ring on the igniter body. It looks like I have to remove the burner top to access underneath. In the center of the burners, there are large brass bolts showing that seem to be part of the gas jet. These seem to be the only thing holding down the top. Do I have to remove these bolts of two burners to turn over the burner top? and how do I do it. Size etc?
Jonathan
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How Do We Remove the Face Plates from the Water Dispenser without Damaging the Plate? melalice Refrigerator & Freezer Repair 0 03-16-2011 05:10 PM
Cooktop Burner Plate Replacement jenvino@sbcglobal.net Oven Repair (including Ranges and Cooktops) 0 02-22-2011 08:14 AM
thermador gas cooktop igniter cshaz1 Oven Repair (including Ranges and Cooktops) 0 09-06-2010 01:10 PM
Thermador Oven PRG304 - Gas only 1/4 Inch High gasco39 Oven Repair (including Ranges and Cooktops) 0 07-06-2009 06:58 AM
how to replace spark igniter probe on Thermador burner jyan Oven Repair (including Ranges and Cooktops) 0 04-23-2009 03:42 PM
