My rgb 745 won't light. It is on Natural Gas. When a burner is turned on, the ignitor fires but it seems the gas valve won't sense the ignition and allow the valve to open for sometimes up to a minute. Eventually, it WILL light, if you turn on the left front, one will light and then the others will follow right behind.
