Discuss
Maytag Electronic Oven Control Panel
 in
My main burner element had a weak spot and burned through one day last week, and when it happened I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag Electronic Oven Control Panel
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-06-2007, 10:57 PM
MDB MDB is offline
Junior Member
MDB is on a distinguished road
Default Maytag Electronic Oven Control Panel
Model Number: CWE9000BCE   Brand: Maytag   Age: More than 10 years
My main burner element had a weak spot and burned through one day last week, and when it happened I think it shorted out my control panel as it went blank. I've replaced the main element - but when I turn the power back on the panel is still blank except for a few -- ---'s and none of the touchpad controls do anything. The fan runs though constantly - which is also why I think the control panel must have overloaded as it's still telling the fan the oven is on. I'm not sure of anything else to do other than replace the panel. You show it as part # AP 382974. Does this dagnosis sound right to you?
thanks
MDB...........
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-07-2007, 02:15 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad control board.
In order to provide you with the right part number I need you to post the serial number of the range.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-07-2007, 03:28 PM
MDB MDB is offline
Junior Member
Default Oven Control Board
Thanks for the reply. I got the part number noted earlier from looking up the serial # and tracking it to series 10, then finding the part on your site - printing off the photo you had of the back of it which was a HUGE help. I was able to walk it over to the oven and compare it to the actual panel as well then to make sure that it was in fact a perfect match. Ordered today from you guys. Your site was the only one I found that had both front and back shots of all the control panels that even after looking up the part number, allowed me to visually match it as well - which is a plus with something like this. Last thing I want is to order a $160 part and have it be wrong, and take even more time to get another.
thanks
MDB....................
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing oven control panel brad Oven Repair (including Ranges and Cooktops) 2 07-14-2008 02:55 PM
Kenmore Electric Range clock / oven control panel dezrailer Oven Repair (including Ranges and Cooktops) 1 11-27-2007 02:46 PM
Electronic clock control peter e Oven Repair (including Ranges and Cooktops) 1 10-26-2007 04:31 PM
Question about replacing an oven control panel Arnheimacres Oven Repair (including Ranges and Cooktops) 0 10-02-2007 06:09 PM
Electronic Oven Control andye Oven Repair (including Ranges and Cooktops) 3 08-01-2007 07:45 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
