The other night I was baking something at 450, after about 10 minutes there was a popping sound. Whatever it was popped the breaker. We turned the breaker back on, and everything on the oven works except the Bake and Broil function. Someone told me to change the elemnts (which they probably needed anyways) so I did (just the bottom). This did not fix the problem. The display, stove top, fan, clock work, just not the oven part...Please Help:mad:
Originally Posted by: Aelray The other night I was baking something at 450, after about 10 minutes there was a popping sound. Whatever it was popped the breaker. We turned the breaker back on, and everything on the oven works except the Bake and Broil function. Someone told me to change the elemnts (which they probably needed anyways) so I did (just the bottom). This did not fix the problem. The display, stove top, fan, clock work, just not the oven part...Please Help:mad: Aelray, You'll need to turn the power off to the range, remove both back panels from the back, and check for shorted damaged wires between the clock/control and the oven elements. Good Luck, :) :) :)
