Discuss
Heating Problem
 in
My GE Spectra XL 44 gas oven does not maintained proper heating. How do I determine if the problem is
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Heating Problem
  #1 (permalink)
Old 12-06-2007, 09:55 AM
Lynn Wachter Lynn Wachter is offline
Junior Member
Lynn Wachter is on a distinguished road
Question Heating Problem
Model Number: Spectra XL 44   Brand: GE   Age: 5 - 10 years
My GE Spectra XL 44 gas oven does not maintained proper heating. How do I determine if the problem is a sensor, igniter or thermostat? Any sugggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-06-2007, 05:10 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to provide the most accurate advise I need the complete model number of the range. You can find it on the frame behind the bottom drawer. XL44 is not a model number.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-11-2007, 11:36 AM
Junior Member
Default
Gene,
The model number for my GE XL 44 is JGBP31WEC4WW, serial number SD232600P.
Thank You.
  #4 (permalink)
Old 12-11-2007, 12:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Lynn
Does it heat up at all?
If it does, what is the difference between the real temperature and the set temperature?
If it does not heat up, check if 120V is coming to the oven igniter when the control calls for the heat.
If there is 120V then the igniter has to be replaced.
If there is no 120V then the control board has to be replaced.
If the difference between the real oven temperature and the set temperature is within 35 degrees range - it could be calibrated.
You can find the instructions in the "Use and care" manual (page 21).
- The part number for the oven igniter AP2014008
- The part number for the control board AP2632480
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thanksgiving Oven Problem.....its still a Problem! rbmattila Oven Repair (including Ranges and Cooktops) 1 03-03-2008 10:05 AM
gas dryer heating problem sakks Dryer Repair 1 09-14-2007 06:45 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
