Discuss
Test Stove Burner Switch
 in
Is my stove burner switch bad. If yes, which is a replacement part # because you don't list one. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Test Stove Burner Switch
  #1 (permalink)
Old 04-27-2009, 03:53 PM
Junior Member
fredhoffmann is on a distinguished road
Question Test Stove Burner Switch
Model Number: JMS27001A   Brand: GE   Age: More than 10 years
I checked the burner ohms and it was 40 to 100 I don't remember
I checked the continuity and did not get a reading
So the burner is good.
With switch in OFF position:
Ground to H1 shows 10 volts
Ground to H2 shows 120 volts
Ground to P shows 17 volts
Ground to L1 shows 240 volts
With swith in ON position:
Ground to P shows 240 volts
Since H1 and H2 go to the burner leads 120 volts won't make it work.
Please help.
Related Models
General Electric JMS27G*01 GE FREE-STANDING / DROP-
General Electric JMS27G*H1 Electric range
General Electric JMS27G*J1 Electric range
General Electric JMS27G*J2 Electric range
General Electric JMS27G*J3 Electric range
General Electric JMS27G*J4 Electric range
General Electric JMS27G0J3 ELECTRIC DROP-IN RANGE
General Electric JMS27GJ4 ELECTRIC DROP-IN RANGE
General Electric JMT10F01 Electric range
General Electric JMT11F01 Electric range
General Electric JMT1901 Electric range
General Electric JMT19F01 Electric range
General Electric JMT2001 Electric range
General Electric JMT20F01 Electric range
Jenn-Air JMV8000ADB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000ADW MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAQ MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAW MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDQ MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDW MWAVE- MOUNTED UNDER CABINET
Maytag JMV8100AAB MWAVE- MOUNTED UNDER CABINET
Maytag JMV8100AAQ MWAVE- MOUNTED UNDER CABINET
Maytag JMV8100AAS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8166BAB MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8166BAS MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8166BAW MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8186AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8186AAB14 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV8186AAB16 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Jenn-Air JMV8186AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8186AAS14 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV8186AAS16 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Jenn-Air JMV8186AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8186AAW15 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV8186AAW17 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Jenn-Air JMV8196AAB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196AAQ MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196AAS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196AAW MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196ACB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196ACQ MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196ACS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196ACW MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8208AAB MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208AAQ MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208AAS MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208AAW MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208ACB MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208ACS MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208ACW MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8208BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BAB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BAB17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BAS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BAS17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BAW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BAW18 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208BCB MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BCB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BCB17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag JMV8208BCB18 Microwave Oven/Hood 2.0 Cu. Ft.
Jenn-Air JMV8208BCS MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BCS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BCS17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag JMV8208BCS18 Microwave Oven/Hood 2.0 Cu. Ft.
Jenn-Air JMV8208BCW MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8208BCW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208BCW18 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag JMV8208BCW19 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag JMV8208DB00 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag JMV8208DP00 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag JMV8208DS00 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag JMV8208DW00 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Jenn-Air JMV8208WB0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208WP0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208WS0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV8208WW0 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Jenn-Air JMV9169BAB MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV9169BAP MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV9169BAS MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV9169BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV9186WB0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WP0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WR0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WS0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WW0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMW2327WB00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2327WB01 MICROWAVE
Maytag JMW2327WS00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2327WS01 MICROWAVE
Maytag JMW2330WB00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2330WS00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2427WB00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2427WB01 27" MICROWAVE / WALL OVEN COMBO
Maytag JMW2427WS00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2427WS01 27" MICROWAVE / WALL OVEN COMBO
Maytag JMW2427WW00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2427WW01 27" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WB00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WP00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WR00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WS00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WW00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WB00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WB01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WP00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WP01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WR00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WR01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WS00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WS01 30" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW8130AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130DAB WALLOVEN- S/C MWAVE ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
What should I test next to fix my stove? edee_em Oven Repair (including Ranges and Cooktops) 6 02-04-2010 08:26 PM
how do you test water level switch ldutton Washer Repair 4 10-14-2009 05:52 PM
GE electric stove burner switch replacement David Matthew Oven Repair (including Ranges and Cooktops) 0 08-26-2009 06:06 AM
Dryer Door Switch Continuity Test sethook Dryer Repair 0 08-23-2009 06:27 PM
Whirlpool Top Stove Burner Switch hthreeq Oven Repair (including Ranges and Cooktops) 2 08-19-2008 11:03 AM
