| » Main top will not lift |
Model Number: sf360BEEW Brand: Whirlpool Age: More than 10 years
I have posted a couple of times. Oh well, give it another try. The main top I am trying to remove from a gas range/sealed burners/ignitor type range, will not lift in the back. The front clips will loosen to let the top up about two inches, but for some reason the back under the control panel will not lift. Job aid says to prop up top after loosening clips on front, but it will only prop up about two inches, and I can't access under main top to replace electronic ignitors. There are instructions for removing the top, but you have to remove the burners and the unit is over 20 years old, and the screws are rusted that are holding the burners to main top. Took one screw out, but the other one on burner broke off at the head. So it isn't practical to remove the burners, could be costly. Is there a latch or something holding the rear main top from lifting. Thanks, any help appreciated.
Thanks! I am not to familiar with stripped screw taps. I use to use them years ago when I was a welder, but haven't used them in a while. Is there any specific type you use. Any type made for appliances. Any certain size. The screws are small, do you have a size to reccomend. I know it's a lot of questions, but I appreciate the advice. Thanks!
| Display Modes | |
| Would like to lift the GE Radiant Cooktop up | mylan10 | Oven Repair (including Ranges and Cooktops) | 1 | 12-20-2009 08:10 AM |
| How to lift top on Kenmore Model 665 Range | pghdan | Oven Repair (including Ranges and Cooktops) | 3 | 03-27-2009 12:32 PM |
| Microwave lift | jcnelson | Microwave Repair | 2 | 03-10-2009 07:29 PM |
| can't re-lift transmission/clutch assembly | Chrispy0818 | Washer Repair | 0 | 11-17-2008 06:47 PM |
