Discuss
Lifting Main top on Gas range
 in
Having a bit of trouble lifting a main top on sealed ignitor top burners. Gas Range, Whirlpool. Can't access
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Lifting Main top on Gas range
  #1 (permalink)
Old 12-06-2007, 04:42 AM
vornato vornato is offline
Junior Member
vornato is on a distinguished road
Default Lifting Main top on Gas range
Model Number: SF360BEEW   Brand: Whirlpool   Age: More than 10 years
Having a bit of trouble lifting a main top on sealed ignitor top burners. Gas Range, Whirlpool. Can't access under top. The clips on the front will loosen to lift front, about two inches, but the back of main top will not lift. Job aid says to remove main top, after removing sealed burners, push right or left to loosen hinge from under control panel, But the Burners screws are rusted and won't come out. Can't the top just be lifted without removing burners, is there a latch or clip holding the main top in back from being lifted. Any help appreciated. Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-06-2007, 04:53 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
You can not remove the top panel without removing all burners first.
Rusted screws is a very common problem with most of stoves and the only way to remove them is to drill them out and replace with a new screws.
If you need to replace just a burner igniter, you do not have to remove all burners. Remove the one with the bad igniter, cut off the igniter wire and attach new one, using a wire nut.
- Here are the break down diagrams for the Whirlpool range Model SF360BEEW0
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-07-2007, 06:04 AM
Junior Member
Default MAin top and burner ignitor replacement
Thanks! For info. I kind of had my suspicions, but had to double check. When drilling out a screw on an appliance, won't it hurt the threads. And if so, don't you then have to use a tap and dye set, or in this case a complete burner and ignitor replacement. Do the screw extractors, like the sears screw out exractors work on these situations. The screw out extractors I see advertised claim that all you need is a drill and the screw out extractors for them to work. Do you have any experience with these tools. Thanks for info.
  #4 (permalink)
Old 12-07-2007, 11:37 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This is a sheet metal screw which goes into the top panel, not into the burner body.
After you drilled it out, you can use a bigger screw.
__________________
  #5 (permalink)
Old 12-12-2007, 02:10 PM
Junior Member
Default Main top burners
I wish I had thought of that. I thought the burners were threaded. The stove I was working on is old, and rusty. I didn't want to damage it any further with all the rust and stuff. Had I known the burners were not threaded I could have easily tapped on them to loosen them, then gotten the screws out. Wow what a dope I was. Glad you pointed that out, to late for me on that one, but I didn't do to much damage to the burner itself other than a little larger screw hole, will this effect the operation of the burner. I haven't replaced the ignitor yet, got to buy one! I just hope it's the ignitor. All the other ignitors are working. I hope the switch is O.K. How do you check the switch! Thanks!
  #6 (permalink)
Old 12-12-2007, 03:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If you can hear the spark when you turn the knob "on" - the switch is fine.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
installing the Assy, main bearing jdouglas14 Washer Repair 4 12-03-2007 06:33 PM
Cooktop stove main top will not come off vornato Oven Repair (including Ranges and Cooktops) 0 12-03-2007 11:08 AM
Installing the main belt cutco760 Dryer Repair 1 11-01-2007 04:57 AM
lifting the door davcat5 Refrigerator & Freezer Repair 0 08-11-2007 07:09 AM
Main pump motor is not activated. gebman1 Dishwasher Repair 0 07-31-2007 11:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
