Discuss
stem replacement
 in
I recently had the right front stem on my Jenn Air cook top replaced; only the wrong part was installed.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » stem replacement
  #1 (permalink)
Old 10-03-2011, 08:57 AM
Junior Member
puff04 is on a distinguished road
Default stem replacement
Model Number: C221   Brand: Jenn-Air   Age: More than 10 years
I recently had the right front stem on my Jenn Air cook top replaced; only the wrong part was installed. The new stem is round front and back and flat on the sides. The original stem was round in the front and flat in the back... while in an off position. Needless to say I can't use the knob which came with the unit, so I have not been able to use the burner. I have research the issue on my own and have found what I think is the correct stem, #8 stem/part #AP4087111, but I am not sure. Hopefully someone can help.
Ads By Google
Related Models
Jenn-Air C221 Surface Unit - Ddraft Ele
Jenn-Air C221-C Surface Unit - Ddraft Ele
Jenn-Air C221-J Surface Unit - Ddraft Ele
Amana C221DW Freezer - Chest
Amana C221FW Freezer - Chest
Jenn-Air C222 Surface Unit - Ddraft Ele
Whirlpool C2257W0
Whirlpool C2257^0
Jenn-Air C226 Surface Unit - Ddraft Ele
Jenn-Air C226-C Surface Unit - Ddraft Ele
Jenn-Air C226B Surface Unit - Ddraft Ele
Jenn-Air C226B-C Surface Unit - Ddraft Ele
Jenn-Air C226W Surface Unit - Ddraft Ele
Jenn-Air C226W-C Surface Unit - Ddraft Ele
Jenn-Air C228 Surface Unit - Ddraft Ele
Jenn-Air C228-C Surface Unit - Ddraft Ele
Jenn-Air C228B Surface Unit - Ddraft Ele
Jenn-Air C228B-C Surface Unit - Ddraft Ele
Jenn-Air C228W Surface Unit - Ddraft Ele
Jenn-Air C228W-C Surface Unit - Ddraft Ele
Amana C22B3W Freezer - Chest
Maytag C22HS  Freezer - Chest
Maytag C22J Freezer - Chest
Amana C23 Freezer - Chest
Whirlpool C2357W0
Whirlpool C2357^0
Jenn-Air C236 Surface Unit - Ddraft Ele
Jenn-Air C236-C Surface Unit - Ddraft Ele
Jenn-Air C236B Surface Unit - Ddraft Ele
Jenn-Air C236B-C Surface Unit - Ddraft Ele
Jenn-Air C236B-E Surface Unit - Ddraft Ele
Jenn-Air C236NGB Surface Unit - Ddraft Ele
Jenn-Air C236NGS Surface Unit - Ddraft Ele
Jenn-Air C236NGW Surface Unit - Ddraft Ele
Jenn-Air C236W Surface Unit - Ddraft Ele
Jenn-Air C236W-C Surface Unit - Ddraft Ele
Jenn-Air C236W-E Surface Unit - Ddraft Ele
Jenn-Air C238 Surface Unit - Ddraft Ele
Jenn-Air C238B-C Surface Unit - Ddraft Ele
Amana C23B Freezer - Chest
Amana C23B-1 Freezer - Chest
Amana C23B-1-A Freezer - Chest
Amana C23B-1-C Freezer - Chest
Amana C23B-1-G Freezer - Chest
Amana C23B-1-L Freezer - Chest
Amana C23B-A Freezer - Chest
Amana C23B-C Freezer - Chest
Amana C23B-G Freezer - Chest
Amana C23B-L Freezer - Chest
Amana C23B1 Freezer - Chest
Amana C23B1L Freezer - Chest
Amana C23F Freezer - Chest
Amana C23F-A Freezer - Chest
Amana C23F-AG Freezer - Chest
Amana C23F-C Freezer - Chest
Amana C23W Freezer - Chest
Amana C23W-A Freezer - Chest
Amana C23W-AG Freezer - Chest
Amana C23W-C Freezer - Chest
Whirlpool C2557W0
Whirlpool C2557^0
Maytag C25AALWH Freezer - Chest
Maytag C25ABLWH Freezer - Chest
Maytag C25ACLWH Freezer - Chest
Maytag C25ADLWH Freezer - Chest
Maytag C25D  Freezer - Chest
Thermador C271U
Thermador C272U
Whirlpool C2757W0
Whirlpool C2757^0
Amana C28 Freezer - Chest
Amana C28B Freezer - Chest
Amana C28B-1 Freezer - Chest
Amana C28B-1-A Freezer - Chest
Amana C28B-1-C Freezer - Chest
Amana C28B-1-G Freezer - Chest
Amana C28B-1-L Freezer - Chest
Amana C28B-A Freezer - Chest
Amana C28B-C Freezer - Chest
Amana C28B-G Freezer - Chest
Amana C28B-L Freezer - Chest
Amana C28B1 Freezer - Chest
  #2 (permalink)
Old 10-03-2011, 12:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The part you called "stem" is actually a surface unit switch. The manufacturer used two different kind of those switches for this model. The difference is the configuration of the shaft. It can be a double flat shaped shaft or a D shaped shaft.
According to your description you need the switch with a D shaped shaft. The Part number: AP4087111
you posted is the correct part number.
Here are the breakdown diagrams and Replacement parts for JENN-AIR C221 SURFACE UNIT- DDRAFT ELE | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
I broke off the oven valve stem. Oven still works, but no stem to mount knob. jmfc Oven Repair (including Ranges and Cooktops) 1 02-02-2009 03:20 PM
mounting stem & boot seal + tub bearing replacement abruzzinom@bellsouth.net Washer Repair 2 01-19-2009 05:02 AM
maytag repair stem kit lando Washer Repair 1 12-30-2008 04:00 AM
Mounting stem and boot seal replacement Fishinfool Washer Repair 1 08-26-2008 10:17 PM
ge-leaking at float stem? jjoneness Dishwasher Repair 0 12-21-2007 06:39 PM
