| » Infinite switch and fan switch |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: FDU185 Brand: Modern Maid Age: More than 10 years
My Modern Maid downdraft range/oven blew first the fan switch and then (after a new fan switch was installed) the adjacent infinite switch (also new). I opened up the stove and found the relay behind the grille element was broken - the button exercised by the metal lever was permanently pushed in - and the cleaning element relays were blown to the extent the top metal blade electrical contacts were melted off. What is the probability that replacing these relays (and switches) will fix the problem, and what else should I look for besides a new stove? Could the fan motor be drawing too much current and overloading the switches and relays? Thanks in advance for any advice.
| Display Modes | |
| infinite switch wiring change from 6 wires to 5 wire switch | wiedemanndds | Oven Repair (including Ranges and Cooktops) | 3 | 12-06-2007 12:45 PM |
| Replacing the griddle infinite switch | J Black | Oven Repair (including Ranges and Cooktops) | 1 | 11-19-2007 01:46 PM |
| lid switch | bellport | Washer Repair | 0 | 11-07-2007 07:53 PM |
| Lid Switch | CAN I DO IT | Washer Repair | 0 | 07-24-2007 04:56 PM |
| change out the lid switch | jreythomas@hotmail.com | Washer Repair | 1 | 07-20-2007 05:14 PM |
