I recently ordered a new handle and need installation help. The 2 screws accessible from the back side of the oven door simply attach and hold in place the back side of the door (with a spacer dowel). Screws to detach the handle are inside and only accessible within the door unit. Is there a way to access these inside screws without having to remove the entire outside door panel?? Any help is appreciated....ddeanfl
