Hello,
The thermal fuse on my oven blew-off during a self cleaning. I have done many cleaning cycles without problem so I do not know why it is happening now.
I short-circuited the fuse and the oven appears to be working ok.
The bad fuse is the one directly attached to the connector on the control panel. I could not find the part number for this one, and some pictures I saw are not exactly the same. This fuse is directly attached to the female pin of the connector, so to replace the fuse I need to pull-out the pin from the connector.
Could someone point me to the right part number.
Also should I change the temperature probe as well and any other part that could have miss-function and led to this problem.
Thank,
